Micro Fiche + parts + chain tension + vaccuum balance
Posted: Thu Jul 16, 2009 10:45 pm
Hello Gentleman,
Could someone point me towards a downloadable parts micro fiche for the paso 750?
I had one on my old computer but for some reason it wasn't backed up to the new one and
most likely has disappeared forever.
BTW I'm looking for a new upper chain guide. It was replaced a year or two ago, shows no wear
and yet was rattiling around having broken off the mount before my last ride. I also need a left
hand front signal lense in good condition if anyone has one.
How do you guys measure your chain tension. Manual only mentions the appropriate slack (I recall 20mm) with both a rider and passenger. This adjustment would take 3 ppl to perform. What kind of slack do you guys run measured with an unloaded bike just balanced standing up under it's own weight?
Has anybody adjusted their rear sag? what are the measurments for static sag (bike under it's own weight) & race sag (bike loaded with rider)
Did the mikuni conversion but never got around to the vaccuum balance. Where does one hook up the vaccuum tubes? Couldn't find any ports other than those two little screws on the intake manifolds. Where do you find nipples to screw into those things if they are infact the correct ports. I plan on building a vaccuum balancer per Anetti's specs.
Thanks so much,
Gunther
Thanks so much,
Gunther
