Paso Quit
Posted: Wed Sep 23, 2009 8:59 pm
Fellow Pasoists,
My 88 Paso has no spark and will not run.
Yesterday midway through a great ride my red battery dash light lit up. I tried limping home but did not make it. It appeared to be running off of the battery, until the battery did not have enough voltage to power spark, at which point the engine stopped running. As I waited at the side of a road for a ride home, I checked a few things out.
First, the battery had some voltage, but not enough to turn the engine over, which would seem to indicate it had been running off of the battery (is this what the dash light indicates?).
Second, my Paso has an electrical connection between the battery positive and voltage regulator, which includes an in-line 30 Amp fuse. This fuse was blown.
So today, I've replaced the battery, for good measure, and the blown fuse. No spark/no run. My wiring connections and grounds should be clean and good, as I routinely clean them.
About 15 years ago I had a voltage regulator fail. In fact, it failed to the point of melting the plastic connector which contains all of the wires that connect to the voltage regulator. I've put about 10,000 miles on it since then, with no electrical problems.
It would be nice to run some electrical tests. I am familiar with checking voltage and resistances, but I am baffled about how to perform these tests based on the Paso service manual. Chapter M, page 11 provides some info about checking recharge current, but I can't see how to perform this test without the bike running.
Chapter M, page 14 gives procedures for checking ignition system resistances, but does not give a step-by-step process, so I have no idea how to proceed.
Any insight on what this might be, and simple step-by-step instructions on how to check out my ignition system and components would be very helpful.
THANKS - Dave
THANKS - Dave
