Do Front Brembos have Anti Rattle Springs ?
Posted: Wed Nov 04, 2009 11:27 pm
by Bomber
Hi to All,
Front brake pads on my 92 907IE rattle, like a bag of nails !
Had the bike MOT d here in the uk and the tester thought there was something missing from the Gold coloured front Brembo Calipers.!!
Anyone out there know if there should be anti rattle springs(not sure if thats what they are called)in the front Gold Brembos?
Gerry
Re: Do Front Brembos have Anti Rattle Springs ?
Posted: Thu Nov 05, 2009 12:25 am
by ducinthebay
There are metal cover plates on the top that help hold the pads from rattling. The pins that hold the pads in place, also hold the anti-rattle plates. If a previous owner didn't know quite how to put it all together, they may have bent the spring fingers so that there isn't the tension that was intended.
Posted: Thu Nov 05, 2009 1:21 am
by du907
The original OEM pads come with a metal wire "spring" that keeps tension against the retaining pins to help keep out the rattling. Most after market brands don't have this wire spring. See the picture below.
Posted: Thu Nov 05, 2009 2:24 am
by Tamburinifan
I can`t se the spring in above expl views,
but usually there is one under 22 on black & gold 4piston Brembos.
Lies on top of pads.
Posted: Fri Nov 06, 2009 11:02 pm
by Bomber
Thanks Guys,
I will now need to find myself some springs !
Gerry
Posted: Fri Nov 06, 2009 11:20 pm
http://freenet-homepage.de/carstenbremm ... bo-4Kz.JPG
Brembo pad spring part no. is 120.4196.85
I got some from my Duc dealer once.
Posted: Sat Nov 07, 2009 1:11 am
by du907
In my drawing above, to the left of the word spring, the gray line is the "spring" that I was talking about. Below are some pictures I took of my 1992 907 and some old OEM ducati pads with the spring. The other pictures above of the caliper looks like a later or newer caliper than I have. I remember seeing those calipers on 900ss models.
Posted: Sat Nov 07, 2009 1:33 am
by Tamburinifan
The rattle spring is visioned in Gerhards pic above:
It is the purple colured thingy keeping the pads in place, hold in place by the pin in center of caliper.
Posted: Sat Nov 07, 2009 8:19 am
now that I see du907`s pictures I remember the whole story. When I bought my 4 piston Brembos years back they came w/o pads and the ones I bought then didn`t have the spring wire on top so I got myself the Brembo pad springs. So the need of them will depend on the brake pads you get.
Posted: Sat Nov 07, 2009 11:14 pm
by Bomber
Great info,
Now I understand, I can have pads with springs, or without, and a seperate Spring !
Thanks to all for your quick replies.
Gerry :beer:
