Page 1 of 2
Need good photos of carb linkage!
Posted: Wed Nov 11, 2009 3:18 pm
by jklnhyde
Since I cannot locate a used carb linkage for my Weber, I'm forced to fabricate one if I want to ride my Paso. I need some good close up pics of the linkage extending from the carburator to the throttle cable end. All I have is the cable--and nothing else!
I see the 'ball' connector at the carburetor bellcrank, but there is no 'connection' between the carb and the cable.
HELP!!
Rick
Re: Need good photos of carb linkage!
Posted: Wed Nov 11, 2009 3:29 pm
Rick,
I can make some pics by tomorrow.
Posted: Wed Nov 11, 2009 11:09 pm
by higgy
Must not have looked very hard :lol: whiner,someone call a whambulance :cool:
Just kidding Look here
http://www.piercemanifolds.com/linkage.htm
and bring cash lots of it :choo:
What do you have to trade? I have all you need :mrgreen: :mrgreen: :mrgreen: :choo:
Posted: Thu Nov 12, 2009 1:41 am
by jklnhyde
Nice link, but it doesn't solve my problem; I still don't know what is missing. If you have what I need let me know a price...
Posted: Thu Nov 12, 2009 4:48 am
by jayh
Hope these will help?
This is the end that the cable comes in
if you need some measurements let me know
Rgds Jay.
Posted: Thu Nov 12, 2009 10:53 am
Posted: Thu Nov 12, 2009 11:02 am
by higgy
You need both ends of the cable? or just whats on the carb? Choke stuff too?
Posted: Thu Nov 12, 2009 12:08 pm
2mm material thickness, edges rolled for better stability.
@jayh
what is that thing infront of your carb, a fuel pressure regulator ?
Posted: Thu Nov 12, 2009 2:57 pm
by jklnhyde
Excellent shots, fellas'! I see that the adjustable rod, spring and black rubber thing are all that I'm missing. If anyone's got them lying around, I will gladly pay...
Rick
Thanx!!!
Posted: Thu Nov 12, 2009 5:16 pm
so you`re just missing the accelerator cable ? That`s all one piece. (I think)
I thought you`re missing the bracket that holds it.
Posted: Thu Nov 12, 2009 6:19 pm
by jklnhyde
ell, if you look at the last photo posted by paso750, you will see everything I am missing. My throttle cable is attached to the throttle tube/housing and it moves, but the carb end of the cable just has a metal 'knob', like most throttle cables.
Does the original cable bring the spring, plastic thing and adjusting rod all attached to it?!
I don't think so, but I might be wrong; I think the assembly in the photo that I'm missing is separate from the cable...
Rick
Posted: Thu Nov 12, 2009 7:00 pm
by jayh
Thats right Paso750 its the holley 12-804 fuel reg mounted upside down,fits in there
just nicely with easy access to mounting screws and a hex key can easily be used from between forks to adjust :thumbup:
Jay.
Posted: Fri Nov 13, 2009 12:28 am
by Desmo_Demon
paso750 wrote:Image
Looks like a ball-and-socket design. If you are missing the ball section on your carb, you may be able to substitute a shouldered bolt in it's place. You might need to use a bolt with a bushing to get the correct diameter (and a couple of washers, but I'm sure you can get it to work.
Posted: Fri Nov 13, 2009 2:28 am
by higgy
So all you need is the cable ?
Posted: Fri Nov 13, 2009 2:53 am
by jklnhyde
Okay, here's the deal: the ONLY thing I am missing from my Paso's throttle cable linkage are the parts in the last photograph provided in the post by paso750. It's the ball socket-threaded rod-coil spring-plastic spacer looking thing. Nothing else. ;)
If this assembly is part of the throttle cable assembly, then, yes, I do need a new throttle cable assembly.
I hope I didn't confuse anyone...
Rick
