Spring rate f different riders?
Posted: Tue Nov 24, 2009 7:38 pm
by Tamburinifan
What are the correct springrates for f e 70-80-90-100 kg riders?
Anyone has a clue?
Re: Spring rate f different riders?
Posted: Wed Nov 25, 2009 1:12 am
by higgy
you can use their calculator to customize your spring rate G
http://www.sonicsprings.com/catalog/cal ... g_rate.php
I think the proper sag is more important than custom spring rates for most riders.Few riders know how to do it properly....Not that I think you have that issue :thumbup:
Perhap we should add a section here for howto's beyond the FAQ for basic setup,just a thought
Also spacers can be used to raise the pre-load on most forks
Posted: Wed Nov 25, 2009 1:38 pm
by injected
higgy wrote:I think the proper sag is more important than custom spring rates for most riders.
Correct for all riders! If your static and loaded sags are both correct, you have the right spring. If one of the sags is wrong, the only fix is to change the spring.
For you, something like a 0.90kg/mm spring would be a good place to start.
