Seat Fix
Posted: Sat Jan 09, 2010 6:27 am
by Duc906
For those that are having trouble with their seat moving forward and releasing from the latch at the back while they are riding,I have a fix.All I did was to cut a piece of fuel hose down the side and slip it over the back of the fuel tank mount,add a bit of silicon to keep it in place,simple.If one piece is not enough just add another over the top.
Re: Seat Fix
Posted: Sat Jan 23, 2010 4:16 am
by Mc tool
Now thats the sort of repair I like to see, cheap , effective and not unsightly. Pity you didnt use #8 wire to hold it on but there you go .
. So when did you move from NZ
.If the rest of that bike is as clean and tidy as the bits I can see it will be a nice bike
regards
hamish
Re: Seat Fix
Posted: Tue Mar 02, 2010 4:23 am
by duckboy
Hiya Ken
this incident first happened to me, whilst on a ride... a long way from home. unfortunately when the seat swung off, the rubber bumps under the seat tore the wires out of the battery, and killed all electrics. (so there was a bodgey roadside repair to the wiring, and half a roll of duct tape used to secure the seat.)
annywaay... here is how I solved the problem.
It looks a bit rough, but it does the job.
cheers
Brett
Re: Seat Fix
Posted: Tue Mar 02, 2010 7:33 am
by persempre907
Re: Seat Fix
Posted: Tue Mar 02, 2010 8:02 am
by Duc906
Hey Duckboy
Good to here from you.
Hopefully your rear end was still not in the seat when it hit the ground. Your fix is a bit less agricultural than mine,good work.
Re: Seat Fix
Posted: Tue Mar 02, 2010 9:59 am
by duckboy
Luckily the seat never actually hit the ground, I was able to trap it between my leg, and the sidecover as it was half hanging off. It happended after a large bump in the road which lifted me out of the seat (actually the seat came with me), I think it snapped the wires (to the battery) as I was trying to re-position it without stopping.
Brett
Re: Seat Fix
Posted: Fri Sep 28, 2012 5:58 pm
by hardo
Dear all
I have the same problem and just the fix provided by duc 906.
It helped for quite a while but the problem is here again. The fixing at the end of the seat (rear end of the the paso) pops of.
Any suggestions for a quick fix?
Thank you, Hardo
Re: Seat Fix
Posted: Fri Sep 28, 2012 11:50 pm
by stigonpaso
I'm planing to go the Duckboy route by putting a thicker plate on the end of the seat.
Re: Seat Fix
Posted: Sat Sep 29, 2012 12:23 am
by Mc tool
Duc906 wrote: Your fix is a bit less agricultural than mine,good work.
Either of those repairs would make any Kiwi beam with pride
. Im wondering ( without racing out to look at my bike ) if the seat is being properly supported ( rubber buffers ) , if not it maybe that the seat base is bowing under rider( and pillion ) weight making the seat a bit shorter and .......
Re: Seat Fix
Posted: Sun Sep 30, 2012 9:17 pm
by JWilliam
Not heard of this one. I got around this by using a Diopa single seat unit for the last few years apparently. It must be the plastic under tray deforming... tricky.
Re: Seat Fix
Posted: Thu Feb 21, 2013 12:23 am
by lane1feathers
I used the now obsolete muffler retaining bolt, drilled out the hole a bit, and glued it in with some REAL GOOD glue. (Obsolete as I have after market mufflers)
Works real good
This is more of a trial to see if I can successfully upload a pic to my thread, so bear with me!
Re: Seat Fix
Posted: Thu Feb 21, 2013 12:24 am
by lane1feathers
....damn.....
Re: Seat Fix
Posted: Thu Feb 21, 2013 9:01 am
by paso750
fixed
Re: Seat Fix
Posted: Thu Feb 21, 2013 11:40 am
by lane1feathers
Awesome, it worked
Now I can put it up here instead of just a link
Thanks G.
PS feel free to delete these last messages
