Yamaha Headlight conversion
Posted: Fri Feb 26, 2010 12:37 pm
by 21783mike
I bought the FZ headlight which was on ebay, now I was wondering if anyone had some hints for installing it.......... everything I found with search was rather old posts that really didn't explain well.
Re: Yamaha Headlight conversion
Posted: Fri Feb 26, 2010 12:53 pm
by paso750
Posted: Fri Feb 26, 2010 2:06 pm
by 21783mike
Reread again... I am not in europe and don't have the euro switch... I suppose ignore the switch mod., and ignore relay #3 and I should be good to go?
Posted: Fri Feb 26, 2010 2:59 pm
by paso750
what`s the difference between euro and US switch ? My switch has the small switch for Hi/Lo and the big one for OFF/Parking light/ON.
Posted: Fri Feb 26, 2010 3:06 pm
by 21783mike
paso750 wrote:what`s the difference between euro and US switch ? My switch has the small switch for Hi/Lo and the big one for OFF/Parking light/ON.
We in the USA aren't allowed to turn off our headlight, so no OFF/Parking light/ON.
Posted: Fri Feb 26, 2010 5:01 pm
by jcslocum
Mike,
Witht he dual headlight version, I would take the time to install a relay to feed the power to it. What you would do, is run a direct lead (with a fuse in it) to the battery or starter solenoid (I prefer the solenoid) to fee the 2 lights direct and not thru the original harness. You then use the handlebar switch to manage the relay and tnot the full load.
Are you eletrically handy or will you need a drawing and such??
Posted: Fri Feb 26, 2010 5:08 pm
by paso750
if you don`t have the ON/OFF switch you can do w/o relay 3, but you should run a yellow lead from the right headlight to relay 2 otherwise only hi beam will work on the right headlight.
Posted: Fri Feb 26, 2010 6:08 pm
by 21783mike
jcslocum wrote:Mike,
I got it, have done all the other relay mods... only one to do yet is the headlight.
Posted: Sat Feb 27, 2010 3:15 am
by higgy
Dual H4's without the relay will melt your ignition switch in short order(pun intended)
Take my word for it :,(
Posted: Sat Feb 27, 2010 2:06 pm
by jcslocum
higgy wrote:Dual H4's without the relay will melt your ignition switch in short order(pun intended)
In fact the normal headlight will do this over time! The double will DEFINITELY melt it and fast.
Higgy do you have some personal experience you would like to share??
Posted: Sun Feb 28, 2010 10:27 am
by 21783mike
Anyone have a pic of the fuse block end of the wiring..... not sure if I am clear on that part and bike is 60 miles away.
Posted: Sun Feb 28, 2010 1:07 pm
by h1a
When i did my dual headlight conversion I used shellboss wiring diagram but modified it a bit, instead of modifying the headlight switch i added an extra swich in the dashbord to be able to run dual or singel lowbeam.
By h1a at 2010-02-28
