side panel fairing + boots = scratches
Posted: Fri May 20, 2005 6:45 pm
Is it just clumsy me or did you also accidently left your Paso with scarifications on the side panels after a fast
but satisfying ride?
Last time I had ridden my Pearl White Paso I wore boots with zippers on the outside and inside of my boots. On my Nuda SuperSport that was no problem, but later on, when I was polishing my Paso I discovered deep scratches, grooves so deep there was no paint left...
I must say my clutch didn't work on my way back home, so I had to yank(?) the lever fiercely..., but on the right side it was the same (not a lot of braking
)... scratches....
Now I am going to use some transparent foil on those weak spots on the panels... I hope that works out.
I also noticed some spots on the tank where my knees are, but to sticker my entire 907ie... not an option I think...
