Wheel Change and Tire choice 750/906 My idea ?????
Posted: Mon Mar 29, 2010 10:45 am
by englishstiv
Okay first of all I have a 907ie so cannot cross reference by looking exactly.
I was checking out a 1999 Aprilia 250 this weekend and noticed that the wheels would actually look like a decent replacement on a Ducati which got me thinking about the awful tire choice you folks have with the 750/906 which I have offered my thoughts on else where already.
So why not the Aprilia
on the Aprilia Front suspension travel: 120 mm (4.7 inches) Paso 125mm
on the Aprilia Rear suspension travel: 130 mm (5.1 inches) Paso 135mm
Front tyre dimensions: 120/60-ZR17 Paso 130/60 -16
Rear tyre dimensions: 150/60-ZR17 Paso 160/60 -16
Front brakes: Dual disc
Front brakes diameter: 298 mm (11.7 inches) Paso = 280mm
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches Paso = 270mm
Obviously there is the sprocket, spindles and brake calipers to sort out but the dimensions seem more positive than negative and it's an idea.
Also on a positive side they seem fairly cheap and available as spares on ebay compared with some other alternatives and Italian (of sorts)
Okay lets discuss or ignore :wacko: :choo:
Re: Wheel Change and Tire choice 750/906 My idea ?????
Posted: Tue Mar 30, 2010 2:30 pm
by riascns
It looks like 16" wheels are starting to be taken up by the racing faternity again. Yamaha endurance austria (Yart) are selling 16" PVM wheels
http://www.yart.at/yart/index.php?page= ... Itemid=109
I mailed them about intermediate or wet tyres and they say that they are under development and not available to the public yet.
I am sure tyres will be available soon to the public.
Yes, I realise such tyres will not be road legal, but for those with an open mind who live in less policed parts of the world they are likely to be an ideal solution.
Posted: Tue Mar 30, 2010 3:32 pm
Steve, I originally wanted to follow your suggestion and ignore this, but I have to ask :)
Where`s the advantage of this wheel set to any other ? The sizes are 3,5 & 4,5x17 and the required modifications are generally the same as on every other wheel set.
Obviously there is the sprocket, spindles and brake calipers to sort out .
not to forget, wheel bearings if necessary, wheel spacers, rear caliper bracket, speedo drive...
PS: your parcel arrived today, Everthing`s fine, THX!!!
Posted: Tue Mar 30, 2010 3:44 pm
by riascns
I think the point was that some wheels are easier to fit than others.
Problem is 17" look too big for the 750.
One of the other posts has a picture of a 750 with a set of wire wheels which look cool
Sean
Posted: Tue Mar 30, 2010 3:49 pm
if the axle diameters match that may be so, still it always needs lots of measuring and some parts machined.
I totally agree about the looks. Also there`re almost no rims that go well with the bikes design (in my opinion)
