Brake master cylinder repair kit??
Posted: Wed Apr 07, 2010 6:10 am
by Mustang505
Hi
does anyone know if you can get new front and/or rear brake mastercylinder spares anywhere? i need to replace seals etc.
Re: Brake master cylinder repair kit??
Posted: Wed Apr 07, 2010 7:48 am
have you tried any Ducati or Brembo dealer ?
I guess the brake pump is the same as on the Paso 750 so the part number of the gasket/repair kit is 037054340.
http://www.mdinaitalia.co.uk have it for 16GBP. There`re also repair kits on ebay but they do cost more.
The part number mentioned comes from the P750 parts catalogue. Strange enough some sellers refer to it as a PS15/16 square shaped brake pump repair kit, but the one of the Paso is a PS13.
Posted: Wed Apr 07, 2010 12:39 pm
by PasoRoo
Hi Clive,
Another excellent source for Brembo kits is www.bevelheaven.com if your Ducati dealer can't help you. The usual sources here in Australia didn't have any overhaul kits in stock for my Paso front master cylinder a month ago, but bevelheaven had them in stock.
Mike
Posted: Wed Apr 07, 2010 9:51 pm
by Mustang505
Thanks for the help guys - do you know when they talk about a 12mm or 13mm master cylinder; are they refering to the diameter of the cylinder? is the standard front on the 750 and Paso 13mm and the rear 12mm?
