just had to take starter aprt - brushes worn out
so starter rotor has been pulled about to get end cap and starter case off (need to clean up commutator)
Assume there is an oil seal between strater and LHS enigne case?
Will this need changing now?
Also any source of new brushes or complete brush holder in UK?
(found holder on ebay in USA)
ta
Dave
starter motor - engine case seal (and brushes)
Re: starter motor - engine case seal (and brushes)
Not if it is not leaking oil into starter.Will this need changing now?
Brushes fr any Duc dealer, one is mounted on the plate.
or from an auto sparky for 1/10th the money ( some assembly requiredTamburinifan wrote:
morbenmabel
thanks
better get on with it then
maybe you`re lucky on the brushes
http://forums.ducatipaso.org/viewtopic.php?f=1&t=2573
