Front Cylinder oil leak
Posted: Thu May 26, 2005 1:40 am
by pope
My 88 750 is using more oil than I believe it should. After removing all of the body work I noticed that there appears to be an oil leak coming from the head/cylinder joint on the front cylinder. After looking in the manuals it appears that there is NOT a cylinder head gasket. Is this true? I'm a little surprised by this. There appears to be only two o-rings.
Has anyone else esperienced this problem? To remove the front cylinder head, do I need to remove the motor from the chassis?
Any help would be appreciated.
Thanks,
Doug
Posted: Sun May 29, 2005 8:05 pm
by Jose
Hello Pope.
To remove the front butt is not necessary remove the engine. The operation of dismounting is not complicated but if you do not have a lot of experience in this type of engine the better thing that they you solve a person with experience.
The problem that you have, I am thinking, it is some of the socket-pans of rubber, these estaran punctured by the age.
