750 paso parts left over
Posted: Sun Jun 13, 2010 6:51 pm
by gitarded
I ended up parting out the Paso. Still have some parts left if anyone is in need. Starter, triple trees, foot shifter and brake asembly, rear master cylinder, exhaust header, headlight cowl support etc etc.
Re: 750 paso parts left over
Posted: Mon Jun 14, 2010 12:17 am
by Duc906
Location?
Posted: Mon Jun 14, 2010 5:35 pm
by fasterdammit
Tell me about your rear M/C ... leaking at all? Good shape? How much do you want for it?
Posted: Sun Jun 20, 2010 11:33 am
by 88WhitePaso750
How is the clutch master cylinder? Do you have the rubber boot for the shift lever?
Posted: Tue Jun 22, 2010 1:37 pm
by fasterdammit
88WhitePaso750 wrote:How is the clutch master cylinder? Do you have the rubber boot for the shift lever?
I'm pretty sure BevelHeaven carries them if you're looking to replace them.
Posted: Tue Jun 22, 2010 11:45 pm
by loki1957
how about a voltage regulator?
Posted: Wed Jun 30, 2010 12:25 am
by skibruce2
I am interested in the gear shift lever from your 750 Paso. Do you know if it is the same as on the 907ie? How much are you asking for it?
Posted: Wed Jun 30, 2010 12:30 pm
by persempre907
skibruce2 wrote:I am interested in the gear shift lever from your 750 Paso. Do you know if it is the same as on the 907ie? How much are you asking for it?
it's the same.
Posted: Wed Jun 30, 2010 1:07 pm
by skibruce2
