907 Ignition keys
Posted: Mon Jun 28, 2010 2:17 am
by Timbo851
Hello all
Can anyone help-Ive lost my keys to my 907 after showing her at a classic bike show in April cant find them anywhere.Does anyone know how I can get replacements,do I have to dismantle the ignition barrel to find a key number??? or what really stuck please help.
Many thanks Timbo
Re: 907 Ignition keys
Posted: Tue Jun 29, 2010 9:13 pm
by riascns
Have you tried your local Ducati dealer?
For car keys, the local main dealer can order a set once you can prove ownership via redisteration document and give them an engine and chassis number.
May be worth a try.
Posted: Tue Jun 29, 2010 9:47 pm
by Timbo851
Mate thanks for reply-have done given in both engine and chasis numbers but were talking about Ducati here they dont exactly have the best after sales back up.Have removed ignition unit and by the looks of it a triple heart by pass op seems easier to get at !!!!
Will continue to try and sort it.
Thanks Timbo
Posted: Wed Jun 30, 2010 8:45 am
by riascns
I remember seeing a while back a parts interchange list that listed an alternative ignition switch for the paso.
The list is at
http://www.motomate.net/parts/
And the switch is:
Paso ignition switch - Gilera 125 SP01
Looking at the forums here, it appears that all paso models have the same switch
http://forums.ducatipaso.org/viewtopic. ... 0&start=30
Sean
Posted: Wed Jun 30, 2010 12:26 pm
by persempre907
The barrels aren't the same on all Pasos: as G. stated, the difference is the height of the upper barrel. 39mm on the 907ie lock and 52mm on the P750/906 lock. (The connector on all is the square one with 6 round pins in it).
Dismantle your barrel and make do some new keys by a good craftsman.
Posted: Thu Jul 08, 2010 9:09 pm
by Timbo851
Posted: Thu Jul 08, 2010 9:43 pm
by englishstiv
Look forward to seeing it out and about when I'm (sadly) in my van.
Posted: Tue Aug 31, 2010 5:00 am
by kgreenlaw
Have the locksmith look up a Fiat Uno key - mine found one that was correct.
The easiest barrel to take off the bike and the least risky for the locksmith to disassemble is probably the helmet lock but the ignition isn't that hard to get off either.
Good luck; may the original key show up the day after like mine did...
--Ken
Posted: Tue Aug 31, 2010 10:11 am
by higgy
Posted: Wed Sep 08, 2010 10:14 am
by 907pasonut
thanks higgy, I'm down to my last key, just ordered 3x #269 blanks
Posted: Tue Sep 14, 2010 10:51 am
by 907pasonut
received the keys yesterday, #269 is the correct key for the 907.
Posted: Tue Sep 14, 2010 8:59 pm
by persempre907
You're lucky.
The MY '91 and '92 have different keys. At least, on my bikes it's so
Posted: Fri Mar 18, 2011 1:55 pm
by Antzo
I was wondering do the original 907 keys write ducati on them ? Mine write ZADI made in Italy are these original or aftermarket?
thanks
Posted: Fri Mar 18, 2011 2:06 pm
by 907pasonut
the original 907 keys have ZADI written on them
Posted: Fri Mar 18, 2011 2:12 pm
by Antzo
SO I have the Original keys YESSSSSSSSS!!!!!!!!!
thanks for the info!!!!
