Champion spark plugs?????
Posted: Sat Jul 10, 2010 9:52 pm
by Vince
Hi, I have a question about these spark plugs the champion RA 6 YC are no longer available. Doeschampion make a sister plug or do I have to stick with my NGKs? Thanks Vince :?
Re: Champion spark plugs?????
Posted: Sat Jul 10, 2010 11:18 pm
by Duc906
Vince wrote:Hi, I have a question about these spark plugs the champion RA 6 YC are no longer available. Doeschampion make a sister plug or do I have to stick with my NGKs? Thanks Vince :?
Champion have replaced the RA6YC with RA8HC. :beer:
Posted: Sun Jul 11, 2010 1:12 am
by higgy
the Champion RA6YC were discontinued a long time ago. The DIRECT replacement is the RA6HC, not the RA8HC which depending on your state of tune may be too hot a plug
Posted: Sun Jul 11, 2010 2:01 am
by Vince
Thanks for the info.. I was also wondering should I go with champs or keep the ngks?
Posted: Sun Jul 11, 2010 11:00 am
by higgy
There have been many discussion here on just that subject, While I normally wouldn't put champions in my lawn mower :lol: :lol:
Many here swear they are a noticeable improvement over the rest and also recommend the RA6HC as the very best choice for any Paso
You can order the RA6HC here http://championiridium.com/
Here is one such thread you can find by using the search function here :thumbup: iridium plugs: if you havn't- try it.
Posted: Sun Jul 11, 2010 3:12 pm
by Vince
Thanks :beer:
Posted: Mon Jul 12, 2010 4:20 am
by ducinthebay
Yeah, I long had the opinion the Champion plugs were not good quality in general, but they seem to be the best in my 1990 Sport. I was skeptical, but after trying them, they run better than the NGK plugs. My local auto parts shop sells them for less than $3.00. Now that I think about it, its been a while, and I should probably change them.
Posted: Wed Aug 04, 2010 1:21 pm
by blazing928
hmmm interesting. I had been chasing an issue with my 450cc 907ie single. [Hori cyl not firing]
I had changed plug wires and new spark plugs when getting the bike sorted after buying it and it had run Ok.[not that I ride it much]
Any way I swapped the coils with the others from the restoration bike, ECU, etc.
There was a spark at the plug, but was running out of ideas, so I put back in the old NGK I had taken out, mmmm fired up perfectly......dud new plug?
1st in my life of 35years playing with cars and of course it has to be on a duke! :banghead:
