flat slides or round slides?
Posted: Mon May 30, 2005 3:21 am
by jprhyme
I wanted to get some info on Paso carbs (again ;( ) anyway, I found out the delortos will run me about 600 for the pair of 36mm PHFs, and the Mikunis about 200-300. Can someone tell me whether I should purchase the round slide or flat slide carb? I surely would hate to order the wrong kind. Its come down to either these or a fuel pressure regulator. Any further help would be great.
If I am correct, I need two of these: http://www.bikebandit.com/partsbandit/p ... 231072.asp
Posted: Mon May 30, 2005 3:31 pm
by jcslocum
A fuel regulator would certainly cost the least but if it's the weber you're trying to fix then yoou may have only small sucess. I have the Dell's but a member has just recently done the change to Mikuni's. Look down thru the threads to see what he has done.
