1987 Paso 750 wiring
Posted: Wed Sep 08, 2010 11:02 pm
by wellerjt
I got my '87 Paso 750 about a month ago. I took all the cowlings off to work on it. Now I can't figure out where the wires go for the horns and the oil temperature sensor on the right side. The wiring diagram doesn't help much. Any help would be greatly appreciated.
Thanks,
jeff
Re: 1987 Paso 750 wiring
Posted: Thu Sep 09, 2010 8:03 am
The wires to the horn are the grey and the green-black one. (The green-black is actually 2 wires in one connector)
The upper sensor in the oil cooler line has a brown wire with an unisolated connector connected to it and a black one which is connected to the main front ground connection.
The lower sensor has a grey wire.
That`s exactly how the wiring diagram shows it.
