Hello,
I will set my rear shock to factory settings, so I can adjust it the way I need.
It is the Öhlins CA 508.
Does anyone know the factory settings?
//Anders
Rear shock settings?
- Skins
The Owners Manual gives only one starting position for the rear suspension preload, which is stated as 'near to the O reference'. Presumably this would apply to both Ohlins and Marzocchi systems. The Manual also says 'Setting Operations to spring load require hydraulic brake adjustments as well' but is no more specific than that.
