906 brake discs?
Posted: Wed Oct 06, 2010 7:52 pm
by nnnnnnorman
Re: 906 brake discs?
Posted: Wed Oct 06, 2010 8:48 pm
by Mc tool
Is there something wrong with your disc's, they do wear a bit but unless they are really thin or warped just give em a clean . When you buy pads make sure the seller knows they are for cast iron disc's . I once fitted sintered bronze pads to a bike with cast disc's and they were the best brakes id ever had on that bike , but the disc's wore faster than the pads
Posted: Wed Oct 06, 2010 9:14 pm
by nnnnnnorman
Posted: Fri Oct 08, 2010 8:47 pm
by persempre907
Posted: Fri Oct 08, 2010 9:42 pm
by nnnnnnorman
good advice. the brake discs worked fine. good stoppers on the paso! ive cleaned em up and put them back on the wheels
Posted: Fri Oct 08, 2010 10:03 pm
by Mc tool
One thing that nearly drove me shotgun mad was washing the bike . The disc's , being cast iron rust almost instantly and unless you make sure the disc's are dry ( like . get all the water out of the holes in the disc ) the 1st time you touch the brakes wipes the surface rust off , combines with residual water and then you get BROWN SHIT dribbling all over your clean ( white ) wheels
I guess its all relative nnnnnnorman, when I got my paso I thought the brakes were pretty good ( and they are ) but when I got the SS ( which is old hat now ) the paso looked a bit dated, having said that Im in no hurry to change them , but when I get round to doing the 17 inch conv I will put the SS disc's, master cylinder and calipurs on with the wheels .
Posted: Sat Oct 09, 2010 7:27 am
by ducapaso
In 17" conversion it's almost needed to switch to 300 or 320 discs and newer calipers
Posted: Sat Oct 09, 2010 8:01 am
by nnnnnnorman
that sounds like a good reason never to wash my bike
i always dry clean the 906 and my other bikes anyway. a damp cloth is as close as it gets to hot soapy water! it seems like a good idea to do the discs and calipers if an extra inch is your plans for your wheels. im going for the avon azoras option and sticking with the little wheels. luckily mine are gold so hide a little bit of road dirt and brake dust. they always wipe up clean enough. i can understand how white ones could be a distraction! the worse thing for me now the tyre issue has been decided are the tyre valves on these little fellows. it is always such a pulaver getting air in and out of them. i have one of those little elbow connectors but boy is it FIDDLY!!!!
