906 Paso Engine Bearing & Seals
Posted: Fri Oct 15, 2010 9:30 am
For those that are contemplating overhauling their Paso engine I have compiled a list of roller bearings and oil seals that are required for the job. The part numbers and detail positions were taken from the original 906 parts catalog.
Enjoy!
Ken (Duc906)
Gearbox
Position.....Ducati Part #....Description.............Size...........Quantity
4.............70120011A.....Split Needle Roller....K24x28x10..........5
17............764020002.....Split Needle Roller....K22x26x10..........1
Clutch
19............46340269A........Oil Seal.............35x47x7.............1
21............751132566........Bearing.............16005................1
23............46370226A........Bearing.............6005..................1
Clutch Cover
17............937842030........Oil Seal............20x30x7..............1
26............46340477A........Oil Seal............75x95x10.............1
Timing (Belt Tensioners)
20............037029350.......Idler Roller...........?**..................2
25............751661238.......Bearing................6201-2RS2/LHT23 ................4
Crank cases
4..............751423380........Bearing.........7207 X2TB (NTN)......1
7..............751302566........Bearing............6305 C3...............2
8..............937832552........Oil Seal............25x52x7..............1
9..............757911747........Bearing............NJ203EC..............2
12............751102054........Bearing.............6004 C3..............1
30............757941542........Bearing..........RNU202 ECP............1
32............751433380........Bearing.........7307 X2TB (NTN).......1
34............937851830........Oil Seal............18x30x7...............1
Water Pump/Alternator Cover
4..............751101747........Bearing............6003 C3..............1
9..............751202374........Bearing.............6001..................2
18............937831524........Oil Seal............15x24x7..............1
26............937831624........Oil Seal............16x24x4..............1 (CORTECO 12010799B)
28............937831625........Oil Seal............16x24x7..............1 (CORTECO 12010801B)
Starter (Driven Gear)
21............061950075.......Needle Roller.....K35x40x13............2
Head Timing (Cams)
12............020470105........Oil Seal............22x35x7..............2
14............751101747........Bearing............6003 C3...............2
19............751102054........Bearing............6004 C3...............2
24............751731542........Bearing............6202 RS1 C3.........2
(As always, this info is given in good faith. All care, no responsibility)
edit by G.:
The waterpump gasket is #78810063A and the same on
Ducati 748 `99 SPS
Ducati 748 SP, Biposto
Ducati 851 Superbike Racing `91
Ducati 851 `90 SP
Ducati 851 `91-`92
Ducati 888 Superbike `92
Ducati 888 `93->
Ducati 906 Paso `88
Ducati 907 I.E. `92
Ducati 916 `94
Ducati 916 Monop.-Senna `95-
Ducati 916 SP `96
Ducati ST 2 `97
Enjoy!
Ken (Duc906)
Gearbox
Clutch
Clutch Cover
Crank cases
Head Timing (Cams)
edit by G.:
Ducati 748 `99 SPS
Ducati 851 `90 SP
Ducati 851 `91-`92
Ducati 888 `93->
Ducati 906 Paso `88
Ducati 907 I.E. `92
Ducati 916 `94
Ducati 916 SP `96
Ducati ST 2 `97
