Brake Light
Posted: Fri Oct 15, 2010 6:14 pm
by hardo
Hi paso fans
may be a simple question but my stop light does not work anymore with the rear break (it works well when using the front brake).
what should i check first?
thank you for your input, hardo
Re: Brake Light
Posted: Fri Oct 15, 2010 7:43 pm
by Finnpaso
Order, buy and change new rear light switch. Its poor quality switch, but little difficult to find any other than Ducati original spare part.
Be carufull when take switch away, as liquid make harm to painted surfaces. And after new switch, u have to take air away from circuit.
Re: Brake Light
Posted: Sat Oct 16, 2010 12:17 am
by higgy
Bevel Heaven has one that works,wiring need to be changed over but easy enough to do
I seem to recall a few folks getting a VW switch that does not need the wiring mod
Re: Brake Light
Posted: Sat Oct 16, 2010 8:00 am
by Finnpaso
Does VW switch function with same oil pressure, as original? What VW modell? year? Ordering number?
Re: Brake Light
Posted: Sat Oct 16, 2010 11:00 am
by higgy
Don't have any more details Antti. Sorry, I just remember running across it in a forum somewhere
what's needed is a 10x1.00 banjo type hydraulic switch
Re: Brake Light
Posted: Sat Oct 16, 2010 5:45 pm
by Finnpaso
surely....
Re: Brake Light
Posted: Sat Oct 16, 2010 7:57 pm
by Mc tool
Seems to me that some of you guys have issues with finding / x matching alternate parts .Maybe we are lucky here , but if I want a brake light sw , oil press sw , temp senders I go to Jim @ allparts who usually hands me a catalogue which has a pic and all the spec's , pick the one I want , pay for it and the courier drops it off at home the next day ( nz$17 for the oil pressure sw on the paso
, I think its for a VW Passat) Do you guys not have this type of auto parts stores ?
Re: Brake Light
Posted: Sat Oct 16, 2010 9:08 pm
by higgy
Re: Brake Light
Posted: Sat Oct 16, 2010 10:38 pm
by Mc tool
Yeah I geuss issues was the wrong word and I had sorta forgotten that some of us here are just starting out bike wise
. You are so right about the true value of a good parts man ( Jim gets his xmas prezzie every year..... money well spent )
Re: Brake Light
Posted: Sun Oct 17, 2010 8:39 pm
by hardo
Dear all
Thanks for the input, I will check my local Ducati dealer and ebay / the net.
We do not have a "Jim @ allparts" job here, I wish we would!
All the best, Hardo
Re: Brake Light
Posted: Thu Oct 21, 2010 7:49 am
by micklm
Hardo,
HEL in the UK do mail order and have a banjo bolt with a built in pressure switch that you should be able to use as a sender for the brake light.....?
http://helperformance.com/store/product ... ts_id=3158
I haven't used one myself yet, but I plan to....
Mick
Re: Brake Light
Posted: Thu Oct 21, 2010 5:10 pm
by Finnpaso
Not so bad idea at all...
Re: Brake Light
Posted: Sun Nov 07, 2010 8:24 pm
by randtcastell
Gentlemen:
Would you by chance know if the Hel brake light switch as on
http://helperformance.com/store/product ... ts_id=3158 would fit on a 750 Paso b.l.s.? Thank you very much for sharing your knowledge.
Best Wishes, Randy.
