Page 1 of 9
Decent Exhaust Pipes?
Posted: Wed Oct 20, 2010 5:48 pm
by Rhino
Sorry forgot to ask: I know I have only owned my 907 since sunday, and "No" I have not yet laid eyes on it but . . .
Where can I get a decent set of (stainless steel) cans or new set of (stainless) pipes so that it sounds like a Duke and not a duck?
Thanks in anticipation
Rhino
Re: Decent Exhaust Pipes?
Posted: Thu Oct 21, 2010 11:52 am
by blazing928
Staintune, ebay, wait, wait, wait, wait :beer: :beer: :beer:
Posted: Thu Oct 21, 2010 5:23 pm
by Rhino
Thanks Nigel
Will check out Staintune
If they work out I'll owe you a few beers
Rhino
Posted: Fri Oct 22, 2010 7:28 pm
by englishstiv
I am about to decore an old set of 907ie pipes to see what interesting tunes can be had with a standard set but will need a bikes to fit them on as mine is stripped for a long term rebuikd.
Posted: Sat Oct 23, 2010 6:35 am
by persempre907
Conti or Gio.ca.moto.
The best you can get.
Ciao :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Posted: Sat Oct 23, 2010 3:06 pm
by Finnpaso
Frankie, You are "MARKETING" ITALY STUFF!!! :mrgreen: Anyway You are totally right, best sounds with those exhausts... :thumbup:
Posted: Sun Oct 24, 2010 2:21 am
by 907pasonut
I'm very happy with staintunes good note and easy to keep clean, it all boils down to personal choice and value for money..... dont forget to match the unrestricted sports cans with an appropiate epprom chip :thumbup:
Posted: Sun Oct 24, 2010 10:19 am
by persempre907
Finnpaso wrote:Frankie, You are "MARKETING" ITALY STUFF!!! :mrgreen: Anyway You are totally right, best sounds with those exhausts... :thumbup:
We Italians love good music :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Posted: Sun Oct 24, 2010 11:03 am
by Rhino
Claude you've just terrified me . . .
Chip? re-programme? epprom? WHAT????
Help me out here guys
Posted: Sun Oct 24, 2010 11:18 am
by higgy
[quoteChip? re-programme? epprom? WHAT????
Help me out here guys][/quote]
Chip tuning refers to changing or modifying an EPROM chip in a car's or other vehicle's electronic control unit (ECU) to achieve better performance, whether it be more power, cleaner emissions, or better fuel economy.
This was done with early engine computers in the 1980s and 1990s. Today, the term chip tuning can be misleading, as people will often use it to describe ECU tuning that does not involve swapping the chip. Modern ECUs can be tuned by simply updating their software through a standard interface, such as OBDII. This procedure is commonly referred to as engine or ECU tuning. ECUs are a relatively recent addition to the automobile, having first appeared in the late 1970s.
As technology advanced, so did the electronics that go into cars. The ECU in a modern automobile, together with advanced engine technology, makes it possible to control many aspects of the engine's operation, such as spark timing and fuel injection. The ECU may also control electronic throttle control (drive-by-wire), valve timing, boost control (in turbocharged engines), ABS, the automatic transmission, speed governor(if equipped), and the electronic stability control system.
Performance gains are realized by adjusting the ignition timing advance. Higher timing may result in higher performance. However, to cope with advanced timing, one must run high-octane gasoline to avoid pre-ignition detonation or pinging. Manufacturers design for a specific timing and this may limit performance accordingly.
In addition, changing fuel maps to coincide with the stoichiometric ratio for gasoline combustion may also realize performance increase. Most manufacturers tune for optimum emissions and fuel economy purposes which can limit performance.
Cars with a turbo fitted can have the requested and allowable boost levels raised, these applications usually have the most effect if the turbo fitted is a low pressure turbo which leaves the most room for improvement.
Another reason to change the ECU map is if there are engine, intake, or exhaust modifications to the car. These "bolt-on" modifications alter the way that the engine flows, often causing the air to fuel ratio to change. Without re-mapping the fuel tables, some of the performance gains from the modifications may not be realized.
A poorly tuned ECU can result in decreased performance, driveability, and may even cause engine damage.
The most common way to 'upgrade' the ECU is using either plug in modules as mentioned above or using a specialist tuner who will use an OBD Flash tool. These devices generally plug into the diagnostic port although in some cases the reprogramming is done directly on the circuit board. Maps are supplied by tuners.
Posted: Sun Oct 24, 2010 12:12 pm
by Rhino
OK Higgy
Where do I take it to get this done? I'm going to fit a pair of replica Contis (my 750 Paso had some and it sounded like a WWII ground attack air-craft).
I always thought you put petrol in them and turned the key.
What?
There's more?
Posted: Sun Oct 24, 2010 12:28 pm
by higgy
You are in the UK? Perhaps Englishtiv can help you out as to where. Or one of the many ducati owners groups you have there.
You can also get set up to do it yourself
Posted: Sun Oct 24, 2010 4:58 pm
by Finnpaso
[quote="persempre907"]
I know that well, You have Conti's and Cio Ca Moto, Termignoni..... and Eros Ramazotti. Laura Pausini and Patty Pravo !!! Little jealous here! :oops:
Posted: Sun Oct 24, 2010 5:31 pm
by persempre907
Finnpaso wrote:..... and Eros Ramazotti. Laura Pausini and Patty Pravo !!! Little jealous here! :oops:
Not be jealous...
Not the kind of music I like.
Only L Twin :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Posted: Sun Oct 24, 2010 5:32 pm
by Rogero
Rhino - where are you based?
