Sitting height
Posted: Sat Jun 04, 2005 6:10 pm
by Petra
Today I bought a 906 paso. It's a marvellous machine but the problem is that my legs are a bit short. Is there a easy way of lowering the machine a bit. Two or three cm should be enough.
Posted: Sat Jun 04, 2005 9:38 pm
by Skins
There are two things you can do: Back off the preload on the rear shock, and set the rear wheel spindle eccentrics in the high position in the swingarm.
Posted: Sun Jun 05, 2005 2:07 pm
by steele
The other alternative is to have the saddle redone with a little less height ....there are differant seats out there
short legs but hands too...
Posted: Tue Aug 08, 2006 3:09 pm
by foxterrier
I lowered the seat about 3 cm, now my heels are on ground (and in same fix the saddle got new colors, red and black).
But still I have troubles to reach to clip-ons... Have anyone tried ST3 clip-ons? I think if they fit and those could change with each other I could raise 5 cm and get those 5 cm closer... *just wondering* ...other possibility was get someone to weld me new ones something like originals but raising backwards and higher...
