replacing 906 rear shock?
Posted: Thu Nov 11, 2010 10:53 pm
by nnnnnnorman
Re: replacing 906 rear shock?
Posted: Fri Nov 12, 2010 12:08 am
by angelix
have you considered a rebuild?
the marzocchi Duoshock is a preatty good unit, the overhauling kit is still available (on ebay AND also through the Ducati stores) and the procedure is not difficult.
The service manual can be found on internet and if you dont want to do it is just a matter of taking it to a service point of any brand with the service kit and the manual and they will do it for 100$ or thereabouts.
Posted: Fri Nov 12, 2010 8:37 am
For example in our downloads section
http://www.box.net/shared/hxsggbv6sl
I`m always very sceptical about used shocks. One actually never knows if the "new" one is much better than the old one.
Posted: Fri Nov 12, 2010 9:48 am
by angelix
paso750 wrote:The service manual can be found on internet
I totally agree with you., after 10000 miles the unit need and overhaul anyway so there is no point in using it as a replacement foir another old one.
Purchasing a 2nd hand unit is is a good idea only when you get EXACTLY the same as yours, you overhaul it and then you fit the new "reconditioned" and keep the old one as spare.
This way you can actually do the swap traight away (2hs job?) without having to stop and store a disassembled bike for a week.
I just started overhauling a Duoshock unit (little knackered but was very cheap) and i managed to buy for 30 EUROS a OHLINS form a PASO750
30 EUROS!!!!!!!!!!! I know it will cost me 200 quid ti fixit (spring & overhauling) in an Ohlins center, but hey, Ohlins is Ohlins...
I can't wait to have it on the bike and try it.
Posted: Fri Nov 12, 2010 9:03 pm
by nnnnnnorman
yes a rebuild is probably a better option. the top eye on my duo is cracked so that will need welding up.
gues i had better take the plunge and buy the rebuild kit. thanks
Posted: Wed Nov 17, 2010 5:24 am
by Xchoppers
Are new, high quality replacement shocks available?
Posted: Wed Nov 17, 2010 8:23 am
Generally there`s WORKS Performance, HAGON, Bitubo which are the cheapest options. The best is for sure WILBERS (these you can have made as you wish w/ or w/o rebound adjuster, w/ or w/o ride height adjustment etc. etc.).
http://www.worksperformance.com/html/home.html
http://www.hagon-shocks.co.uk/main1st.htm
http://www.bitubo.com/
http://www.wilbers.de/index_en.php
I don`t know if WHITE POWER or OEHLINS have something for the Paso, may be worth checking
http://www.wpsuspension.com/index.php
http://www.ohlins.com/
Normannnnn here`s the repair kit
http://cgi.ebay.com/Ducati-PASO-906-Mar ... 2c5383bc87
Posted: Wed Nov 17, 2010 8:41 am
by nnnnnnorman
thanks G
Posted: Wed Nov 17, 2010 5:11 pm
by Xchoppers
Thanks for the great information paso grand pooh-bah!
Posted: Thu Nov 18, 2010 7:12 pm
by Finnpaso
Surely Öhlins have "something" for Paso, no matter do U have 750, 906, or 907IE, as same unit fits to all.... But U have to find then one used one from early 750 Paso...Best of all, if thinking spend money / quality and still totally possible to rebuild with just normal costs with new spare parts from Öhlins.... My "vote" goes to Öhlins, as it is really very good product...
Posted: Fri Nov 19, 2010 12:08 pm
by nnnnnnorman
Posted: Sat Nov 20, 2010 6:08 pm
by Finnpaso
16" wheels look good, but no new Michelin tires for them. Not so bad idea to convert to 17", but surely not so good looking then.....
