New adjustable preload rear shock
Posted: Thu Jan 20, 2011 12:19 pm
by davo
Hi guys, just thought someone may be interested in what i fitted to my 907ie.
The standard shock was rebuilt but the rebound faded out after a short period which was the original problem. I was warned that rebuilds on these are not always successful.
I purchased a new rear shock (marzocchi) from ebay for a 750/906. Prior to buying it i asked for the dimensions and compaired it to my original.
The hole centers were the same so i thought i`d give it a try on the 907. Here are some pitures.
I had to wind the preload down about 10mm using the lock nuts to set the ride height after i noticed the tyre had rubbed a bit on the plastic under guard with a pillion, that was with the extra preload wound up from the remote adjuster as well (backed right off when solo though).
The shock fells good now i think i have it sorted out. It doesn`t have compression damping only rebound at the base.
Re: New adjustable preload rear shock
Posted: Thu Jan 20, 2011 12:30 pm
by davo
Sorry stuffed up pitures. Working on problem. Re-reading instructions...Der!
Posted: Thu Jan 20, 2011 12:40 pm
done. [img] at the beginning and the end of the links was double that`s why they didn`t work
Posted: Thu Jan 20, 2011 12:52 pm
by davo
Do you normally see the pictures in the preview screen? Or just the link?
Posted: Thu Jan 20, 2011 12:59 pm
by davo
Posted: Thu Jan 20, 2011 1:57 pm
by samandkimberly
Nice...how hard was it making up a bracket for the preload adjuster? It didn't just bolt on, did it?
Sam
Posted: Thu Jan 20, 2011 2:13 pm
You see the pictures. If you see the links only there`s a mistake in the links. Some links in Photobucket already have [img] at front and end of the link. In that case it`s not necessary to click on "img" on top of the editing field. If you do the links won`t work.
[img]the-link-to-the-picture[/img] works, [img][img]the-link-to-the-picture[/img][/img] as you had it won`t.
Posted: Thu Jan 20, 2011 5:01 pm
by angelix
that seems the old marzocchi unit fitted on the PASO 750.
I got one of those, it is basically the same as the 907 one (overall dimentions), the only big difference is that the spring is different, the 907 one is 2 times harder; then the internal setup will match the harder spring, however I was told it could work also as it is.
Posted: Thu Jan 20, 2011 9:10 pm
by Jaffa
angelix wrote:that seems the old marzocchi unit fitted on the PASO 750.
Gday Davo,
I have one of these shocks on my bike. It works the way it should however I do think the sping is a little soft as there is a lot of contact of the rear tyre on the underside of the computer box. I have had to patch the hole once but wear continues even though I have increased the preload on the spring. (Perhaps I am a little heavier that I would really like to be too.
I have heard others writing about that issue here and think I will be returning to the original shock once I get my new swingarm.
Good luck with it mate.
Posted: Thu Jan 20, 2011 9:26 pm
by nnnnnnorman
Posted: Thu Jan 20, 2011 11:14 pm
by Tamburinifan
Do you know the factory specs of the spring f 750 & 907?
Posted: Fri Jan 21, 2011 11:06 am
by davo
Hi, yes i agree the spring may be a bit soft. It doesn`t seem to be an issue solo though. I will be trying source a harder one i think. The original spring won`t fit as it is shorter.
The Bracket i made for the remote adjuster was fitted using the 2 bolts holding the rear brake master cylinder.
I paid roughly $150AU for it.
PS, I don`t understand? I couldn`t get the pictures to work in the first thread, now they are there? Sorry poeple that you have to look at them twice...............
Posted: Fri Jan 21, 2011 12:46 pm
by jcslocum
Gerhard corrected the link issue so that they would work properly.
