Weber carb leaks LOTS of fuel
Posted: Tue Feb 08, 2011 8:34 pm
Hi pals,
After 6 and a half years abandoned at the bottom of my garage, las summer I decided to take my good old Paso on the road again.
I started an ordinary revision but I found that there was oil into de combustion chambers. After looking for the right parts here and there I was finally able to rebuild to new the whole upper end of my engine (heads, valves, segments, cilynders....
Saturday it started fine but the fuel tap leaked and I repaired it with the right O-rings.
But today I started it again..... at first it worked fine but after a few minutes problems started... as far as I've been able to see, my weber leaks fuel into the engine (just through the right barrel) and floods everything. Last time I use my Paso, the carb worked quite right, so...
What might be the problem? Any ideas? Float problem? over pressure from pump?
When I turn the ignition key to "on" I hear a bubbling sound of fuel leaking into the carb. After removing ths spark plugs I checked they were very wet and there were lots of fuel into the cilynders (I pumped it out usin the starter)
Thank you in advance for your help, I'm quite a confident mechanic but I have very little knowledge of Webers.
