Page 1 of 2
Radiator coolant container
Posted: Fri Mar 18, 2011 4:44 pm
by Antzo
My coolant container has a crack so it will need replacement. Any ideas were I can find one?
Re: Radiator coolant container
Posted: Fri Mar 18, 2011 5:12 pm
by Finnpaso
If You mean expansion tank, there are not anymore such available from Ducati dealer (for many, many years!), so only way is to fix own by plastic welding, etc fixing, buy from Ebay good one, or make one from aluminium, or use expansion tank from some other bike model (not from any Ducati, expect 906). Check first accurately, from where it leaks.
Posted: Fri Mar 18, 2011 5:34 pm
by Antzo
yes you are right the expansion tank
Posted: Fri Mar 18, 2011 6:45 pm
by Finnpaso
You can find one from Ebay... sooner or later, but many of them are also leaking.... Good luck!
Posted: Fri Mar 18, 2011 8:47 pm
by nojapan
Posted: Sat Mar 19, 2011 2:08 am
by pasolloyd
Antzo,
Your best bet is to have it "plastic welded" by a specialist. Even leaking ones sell for too much on ebay. The cost of repair is very reasonable and reliable if done by the right person. There is no glue that will permanently repair the tank.
Posted: Sat Mar 19, 2011 7:25 am
by Antzo
Well I don't know I have not seen it as I was told by my mechanic over the phone. On monday I am going to the shop to see it .
I am afraid that if the plastic is shot, then you can weld it on one place and after while it might crack next to the weld, or isn't this the case?
Has anyone used a japanese tank or other alternative that will do the job? (japs might not have style but I have to admit they know their business when it comes reliability)
Posted: Sat Mar 19, 2011 12:37 pm
by 907pasonut
one thing that you can do once the tank is fixed is to do the CBR600 radiator cap conversion,
this will keep the plastic tank unpressurized and not have any problems
my tank was in good shape, but I still did the conversion last year as a matter of precaution
you can find the post if you put in a search under "CBR600 radiator cap conversion"
Posted: Sat Mar 19, 2011 4:09 pm
by Antzo
907pasonut wrote:one thing that you can do once the tank is fixed is to do the CBR600 radiator cap conversion,
ok thanks will keep this in mind
Posted: Sat Mar 19, 2011 11:10 pm
by ducbertus
The material of the container is PE and is weldable.
I had mine welded a few years ago and costed € 15, done by a specialist.
If you have a very small torch or soldering gun you can do it by your self.
PE is a so called thermoplastic material, meaning that the material will melt again when heated. with the small torch (size of cigaret lighter) you can do it.
You also can add other PE material if you have to add material.
If you have plastic garbage bins, they probably made of HDPE (high density Poly ethyleen), you can practice before working on the container.
Bertus
Posted: Sun Mar 20, 2011 7:37 am
by Antzo
ducbertus wrote:The material of the container is PE and is weldable.
Bertus
I'll check it out thanks!
Posted: Sun Mar 20, 2011 8:28 am
by persempre907
Posted: Sun Mar 20, 2011 9:57 am
by Antzo
Yes I read about that, but there is a comment that not all years fit, do you have more info on that? Have you used a Pegaso tank on your bike?
Posted: Wed Mar 23, 2011 11:00 am
by persempre907
No, I have read that on "Mondo Ducati", an Italian magazine.
So, I'd go to a dealer who sells Aprilia's spare parts and would check what is the container which can be fitted without modifications.
Posted: Thu Oct 10, 2019 3:31 pm
by BillB01
I searched "CBR600 radiator cap conversion" and I don't get the original post on how to do this. Even a wide Google search for Ducati 907ie CBR600 radiator cap conversion doesn't reveal it. Anyone have the info?
EDIT: To answer my own question, the information can be found in the FAQ as coolant reservoir modification.
http://www.box.net/shared/ou0yii8jnc
