The one w no rebound fuction.
My wheel axle threads are gone, need just the lower part of left M1r leg.
Left M1r fork leg needed!
- 907pasonut
Re: Left M1r fork leg needed!
try iangowanloch@bigpond.com he may have one...good luck
actually this one might be better gowanloch@ozemail.com.au
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
avhpaso
did you find a leg I am looking for the RH side leg
if Gert finds one it won`t help you as the 907ie fork is not the same.
Duc750
- year: 1993
I thought the lower was the same but the actual tube longer, or are the threads different too?
the 907ie has 40mm brake caliper mounts, the P750/906 has 108mm.
Gert has a 907ie, avhpaso a P750.
Duc750
- year: 1993
Got you, wasn't thinking about calipers (but should have been)
seen this ?
It doesn`t say which Paso it`s from, the price is a bit high and the position of the left dust seal looks a bit odd considering all seals were replaced
http://cgi.ebay.de/Marzocchi-fork-41-7- ... 415a61a926
I sent the seller an email and he confirmed that the forks have caliper supports 108mm apart, whiche means they are either P750 or P906 as the 907 has the supports only 40mm apart.paso750 wrote:seen this ?
It doesn`t say which Paso it`s from, the price is a bit high and the position of the left dust seal looks a bit odd considering all seals were replaced![]()
the guy told me the total lenght is 810 mm from standing free on the floor to the top of the valve on top of the fork and the distance from bottom to center first hole of the caliper support is 95 mm.
