Tyre pressures
Posted: Wed Apr 27, 2011 5:28 pm
by Graemer57
Any advice on what tyre pressures to run on 750 Paso. Am 16 stone
34 Front. 38 Rear ???
Re: Tyre pressures
Posted: Wed Apr 27, 2011 6:32 pm
normally I would just tell you to download the manual(s). ;)
But yes, it´s correct.
Congratulations for the new bike. Hope it`s a good one.
Re: Tyre pressures
Posted: Wed Apr 27, 2011 7:36 pm
by higgy
+/- 2 psi Big guy
Re: Tyre pressures
Posted: Wed Apr 27, 2011 7:40 pm
yep, a bit more than recommended in the front seemed to make handling a little better with the old tires.
Re: Tyre pressures
Posted: Wed Apr 27, 2011 8:02 pm
by Duc750
A few more PSI probably made the profile a bit taller.............. like the alternate size fitted to the blade ! :shock:
Re: Tyre pressures
Posted: Wed Apr 27, 2011 8:13 pm
not so much more :lol:
3psi are sufficiant. According to tire manufacturers and dealers I talked to in the past this is in limits that will not make much difference in wear.
Re: Tyre pressures
Posted: Thu Apr 28, 2011 7:55 am
by Graemer57
Thanks for the advice. i had looked in the manual but asked because I wonted to tap into the experience of others who, like me, might not be as slender as they used to be :-) I run my R1200RT with slightly higher pressures as it handles much better that way, especially two up
Re: Tyre pressures
Posted: Thu Apr 28, 2011 11:15 am
by higgy
I'd be happy at 16 stone only another 3/7 to go from 20 a year ago :beer: :beer: :beer:
