Mikuni T38 flatslide questions
Posted: Wed May 11, 2011 3:07 pm
hiya folks...
I have a new to me 1988 750 paso that I picked up over the winter. Pretty good shape (95xx miles on it), previous owner took off the weber and put on Mikuni T38 flatslides, on Malossi manifolds w/ K&N filters. Unknown non-stock dual aluminum exhaust cans (look nice!).
I am just getting into the bike and about to do a baseline belt change and valve adjust...
But, the bike is running a bit rich and the idle will hang up at 3k RPM from time to time - not good! It does not seem to be cable routing, I can hear the throttle slides snap shut. Seems like the carb angle is pretty severe on the horizontal cylinder - am I sloshing fuel into that cylinder and that's my high idle issue? The fuel pump and bypass are in place can I be overwhelming the floats? (saw a little fuel in overflow lines - so either this or the floats are too high).
So just would like some feedback from you listers on what a good Mikuni T38 setup should be for this bike.
1. What angle is allowable on the Mikunis? Malossi manifolds OK? Is that low angle horizontal cylinder manifold out there still?
2. Suggested jetting (ballpark)? - pulling them apart tonight to see whats in there.
3. Fuel pump/bypass or just gravity?
Thanks people!
C
Thanks people!
C
