Page 1 of 2
Trip Reset Nut part number
Posted: Sun Jun 12, 2011 2:10 pm
by plasmid
Does anyone have the Trip Reset cable nut part number - this is the nut that secures it to the dash filler,
fits on the knob.
Can't find it in the parts manual.
Re: Trip Reset Nut part number
Posted: Sun Jun 12, 2011 2:13 pm
by paso750
it doesn`t have one. Something similar was justed asked in the 907ie forum and I`m afraid the complete reset cable is part of the dashboard. There´s no part number for that, either.
Posted: Sun Jun 12, 2011 2:36 pm
by plasmid
paso750 wrote:it doesn`t have one. Something similar was justed asked in the 907ie forum and I`m afraid the complete reset cable is part of the dashboard. There´s no part number for that, either.
Thanks. That sucks.
Took the dash out to repair the odometer and then I think I screwed the nut back on
and taped the cable to the frame - drove it without the fairing for a couple of weeks.
I guess the vibration worked it loose.
Anyone have an extra one to sell?
Posted: Sun Jun 12, 2011 2:43 pm
by paso750
if you`re lucky some hardware store may have round nuts that fit. It will for sure look different though. Probably like this
Posted: Sun Jun 12, 2011 3:40 pm
by higgy
Grainger in the US should have one or McMaster Carr.
Posted: Sun Jun 12, 2011 4:14 pm
by plasmid
paso750 wrote:if you`re lucky some hardware store may have round nuts that fit. It will for sure look different though. Probably like this
Do you have a photo of the original?
Posted: Sun Jun 12, 2011 4:25 pm
by plasmid
BTW - do you guys think vibration could break it loose if it was tightened on the knob (but not mounted on the filler plate).
Didn't pay much attention to it so I don't remember if it locked in place.
If it's unlikely it fell down it should be around here somewhere.
Posted: Sun Jun 12, 2011 5:07 pm
by higgy
Seems to me there is a fiber washer to keep it in place,so if the washer or the filler are gone,for sure
Posted: Sun Jun 12, 2011 5:10 pm
by paso750
there`s one warped thin washer that`s missing here.
Posted: Sun Jun 12, 2011 5:49 pm
by plasmid
Thanks guys.
Guess it fell somewhere.
Posted: Sun Jun 12, 2011 8:18 pm
by JoKing
Yep... if someone finds the cable...please msg me.
Posted: Sun Jun 12, 2011 9:02 pm
by streetsurfer
Take a look under the fairing and tank . Oftentimes a part may lodge somewhere on it's way to the ground. Let's hope that's your case.
I think you could find a suitable replacement at most good hardware stores in the way of a jam nut. Can't recall the specific name for that type nut. apply soft loctite to the replacement maybe. many toggle switches use a similar nut, if you can find the right size.
Posted: Sun Jun 12, 2011 11:28 pm
by plasmid
streetsurfer wrote:Take a look under the fairing and tank . Oftentimes a part may lodge somewhere on it's way to the ground. Let's hope that's your case.
I think they're called knurled nuts.
Interim solution - rubber washer.
Posted: Sun Jun 12, 2011 11:32 pm
by Desmo_Demon
A threaded, knurled nut from an electrical toggle switch from an auto parts store may work,too. It looks similar to the ones on my guitars' potentiometers (volume and tone knobs).
Posted: Sun Jun 12, 2011 11:37 pm
by plasmid
Electric guitar toggle nut - a touch too small.
