tach cable????
Posted: Sun Jun 19, 2011 5:52 pm
by Vince
Hey, do you guys know where I can get a tach cable at :banghead:
Re: tach cable????
Posted: Mon Jun 20, 2011 1:35 am
by Foxtee
Re: tach cable????
Posted: Mon Jun 20, 2011 2:12 am
by Vince
yea but will those fit
Re: tach cable????
Posted: Mon Jun 20, 2011 7:46 am
by Foxtee
Check the maker name on the gauges eg. Veglia or Smiths ,
mine show Veglia on the speedo only, but the thread on both is the same. The speedo cable I got last year fit perfectly.
You could also drop them a email , I've found very helpful.
:D
Re: tach cable????
Posted: Mon Jun 20, 2011 8:19 am
by paso750
beware that different Ducs use the same cable but in a different length.
I had bought one some time ago which should have been for the Paso. I noticed it did pull a little on the rubber guide ring on the fender. I ignored that and kept working on the bike turning the steering once in a while until I noticed the instrument cluster was moving although the rubber dampers were all new. When full steering the cable was pulling on the panel which is why the rubber dampers came apart. The one I have now is a bit longer. Total length is about 900mm.
Re: tach cable????
Posted: Mon Jun 20, 2011 5:28 pm
by Maico88
Don't know about now, but about a year ago I got a tach cable for my 750 Sport from the local Ducati dealer. My Sport has Veglia gauges.
