Time flies
Posted: Thu Jul 07, 2011 8:29 am
by Witzie
Time flies when you're having fun, certainly when you are riding a Paso. But the clock on my PASO dash is taking this too literally, it's running way too fast. An hour takes about a minute to pas, you can see the handles moving. Anybody seen this before? Maybe a simple solution?
Re: Time flies
Posted: Thu Jul 07, 2011 7:32 pm
by nnnnnnorman
Re: Time flies
Posted: Thu Jul 07, 2011 8:59 pm
by scimmione
Time and speed are relative: The faster you go, the more time slows. So, go faster, your clock will slow down!
Seriously though, under Parts Interchangeability Listing =
http://forums.ducatipaso.org/viewtopic. ... ngeability you'll find lots of good fixes and alternatives.
The Paso clock can be replaced by using the printed circuit board from Fiats like the Mirafiori, Tipo and Jaeger.
Re: Time flies
Posted: Thu Jul 07, 2011 9:26 pm
by nnnnnnorman
Re: Time flies
Posted: Fri Jul 08, 2011 12:45 am
by Mc tool
Re: Time flies
Posted: Fri Jul 08, 2011 1:28 am
by higgy
Check out the clock faq
all you need to do is replace a resistor
Re: Time flies
Posted: Sat Feb 25, 2012 6:27 pm
by Witzie
Winter is over in Holland so i took my Paso out for a spin. As my garage is a bit damp i had some electrical problems so i cleaned all the connectors which solved all the electrical problems. Guess what, the clock is also running perfectly!
Re: Time flies
Posted: Mon Feb 27, 2012 8:20 am
by Mc tool
Re: Time flies
Posted: Mon Feb 27, 2012 10:35 am
by Witzie
my house is build just over sea level, must have been rising damp!
