paso750 wrote:angelix do you have the maps from the Pederzini modules and if so from which ones ?
Of course!!!!!!
I have them mapped and ready to go in my Ignitech ECU.
I have also the details of EACH of the 3 modules which are basically the DUCATI PERFORMANCE modules coded as
AL9000-1.1
AL9000-2.4
AL9000-3.0
They differ basically in the the advance curve
-AL9000 1.1 is suggested for for light tuning
from 0 to 1600rpm the ADV is set at 6 degrees
from 1600 rpm to 2800rpm increases from 6 to 30 degrees
from 2800 rpm to 8000 remains at 30 degrees
from 8000 up to 11000rpm goes down to 20 degrees where it remains.
-AL9000 2.4 is suggested for heavy tuning and low RPM torque
from 0 to 2000rpm the ADV is set at 0 degrees (Zero)
from 2000 to 3500rpm it goes from 0 to 30 degrees
3500 to 8500 rpm stays at 30 degrees
from 8500 up to 10800rpm it goes down to 11 degrees where it remains
AL9000 3.0 is for heavy tuning and torque at high RPMs
from 0 to 1800rpm the ADV is set at 6 degrees
from 1800 to 3000rpm increases from 6 to 34 degrees
from 3000 to 9000rpm decreases from 34 to 32 degrees
from 9000 up to 10500rpm goes down to 28 degrees where it remains
There is only one thing that is NOT very clear to me and I will need to do some investigation once I find some time:
- the way the FLYWHEEL is made it has a SET TRIGGER which is fixed (32-36 degrees according to the type of flywheel) and can be modified only by modifying the flywheel by making the trigger longer (refer to :
http://www.bikeboy.org/ducati2vignition.html )
- The standard ignition modules are set up with a starting ignition advance (base advance csetting) which can be modified by moving the position of the pickups back and forwards and this will influence also the MAX advance as this is SET by the flywheel.
- I assume that with the modules starting at 6 DEG from 0 to xxx RPMs , the base advance (position of the pickups) has to be set at 6 Degrees; with the module starting at 0 (zero) degrees the base advance has to be set at 0 (zero) degrees.
Unfortunately I do not have the instructions for the modules, so I cannot be 100% sure of how the base advance has to be set.
With the Ignitech you have only to set the BASE ADVANCE SETTING, then enter this value in the software and after that you can modify in any way you like the advance curve bearing in mind the limits set by the flywheel trigger lenght; if you want to have more than the standard 32-36 degrees you will need to modify the flywheel.
