Page 1 of 2
Thinking of Going Waterless
Posted: Sun Jul 24, 2011 11:22 pm
by giarcg
I still have a good, leak free coolant tank on my '93 and in an effort to keep it that way I'm considering going to waterless coolant. The primary benefit would be the ability to run pressureless which would relieve stress on the tank and the hoses as well. Evans (
http://www.evanscooling.com/ ) supplies the coolant. Anyone have any experience or thoughts concerning this?
Re: Thinking of Going Waterless
Posted: Mon Jul 25, 2011 11:55 am
by blazing928
very interesting , thanks.
I think your idea is sound, but then what would I know!!
Posted: Tue Jul 26, 2011 1:12 am
by higgy
Posted: Tue Jul 26, 2011 10:47 pm
by englishstiv
It's even good for Rats
In tests on rats according to EPA regulations, no rats died eating the ethylene glycol/inhibitor combination, even in quantities that completely filled the stomachs of the rats, indicating a very low toxicity.
Posted: Wed Jul 27, 2011 12:14 pm
by Duc750
So just to clarify is that tested on animals or Triumph owners?
Posted: Sat Jul 30, 2011 12:55 pm
by persempre907
Is there some benefit about the working temperature?
I have my red 907 which works much warmer than the black one.
Above all in the traffic and in the summer is a nightmare.
Any advice?
Posted: Sun Jul 31, 2011 7:05 pm
by rhythminblues
You may need the specialized NPG™ coolant pump, NPG™ radiator with a non - pressurized radiator cap as well as the new Evans NPG™ Coolant.
Um.....
"specialized NPG coolant pump"....For a 907.......hhmmm
Posted: Sun Jul 31, 2011 11:22 pm
by giarcg
persempre907 wrote:Is there some benefit about the working temperature?
Any advice?
From what I've read there is a slight increase in operating temperature when using the waterless coolant so there is no benefit in that regard.
Posted: Sun Jul 31, 2011 11:27 pm
by giarcg
rhythminblues wrote: You may need the specialized NPG™ coolant pump, NPG™ radiator with a non - pressurized radiator cap as well as the new Evans NPG™ Coolant.
Um.....
From what I gather this applies to high performance (racing) applications and only if desired. Elsewhere the web site states " No other cooling system modifications are required for stock vehicles to run NPG+. Simply drain the entire system and fill."
Some users utilize a low pressure (4 psi) cap to maintain some pressure on lip seals. Don't know if it would be an issue here... when I try it I'll report back.
Posted: Mon Apr 21, 2014 5:12 pm
by Ducolaf
Hi there, as I was interested in changing to Evans too, after doing a first service myself on the 907, I was wondering what the experiences are so far.
You need an water absorbtion fluid (can be re used) to wash the system free of old remains and than fill it with the Evans coolant. There are some sevice stations here who are dealer of Evans. Thinking of going there for information and cost.
Updates welcome.
Posted: Mon Apr 21, 2014 9:30 pm
by Mc tool
If the whole reason is to run pressureless ......just leave the cap loose . When I got my paso the cap was knackered .... still is and the only time it ever gave grief was in traffic when it lost a little fluid just as the fan came on
Posted: Mon Apr 21, 2014 10:32 pm
by du907
I use water and water wetter.
http://www.redlineoil.com/Products.aspx?pcid=10
Started using it for track days. Most tracks don't allow anti-freeze. I've been using this for years and haven't noticed a big difference in temperature.
Posted: Mon Apr 21, 2014 11:22 pm
by higgy
The basic idea is to prevent corrosion, As Evans coolant has no water and is electrically neutral all you metals and gaskets should last longer No electrolisis, No electrolytic migration. Hoses and no pressure is just another bennnie
Posted: Tue Apr 22, 2014 6:57 am
by Ducolaf
Indeed, my interest lies in the no corrosions aspects, as well as lifelong use of the fluids. Would not like to see alu parts being eaten away in time.
Who is using it here? Is it an DIY issue or do I have a lof of left-overs on fluids to be stored away. No idea on prices eigher.
Posted: Tue Apr 22, 2014 9:38 am
by lane1feathers
I've bought some but am waiting for one last item to arrive then I can strip and replace a couple of things while doing a service and coolant change out. I'll let you all know how it goes in a couple of weeks if you can wait that long. The main reason I'm doing the waterless route is so I can ditch the expansion tank but if you read the web site you can see many other benefits. It's more expensive but lasts the life of the engine...unless you spill it!
