Engine running bad when tank is less than half full
Posted: Tue Aug 02, 2011 11:26 am
by Witzie
When my fuel tank is less than half full my engine is beginning to run bad. The emptier the tank, the worse it gets. This way I can only drive for about 140 km (80 miles) This surely has something to do with fuel pressure, is there any way I can increase the pressure? May be a different fuel pump?
Re: Engine running bad when tank is less than half full
Posted: Tue Aug 02, 2011 10:27 pm
by higgy
It aint pressure related directly
you got crap in that thar tankie my freind,clean it out.....or yer vents be blocked,clean them too
Posted: Wed Aug 03, 2011 5:56 am
by Mc tool
Is the fuel pump actually working ?
Posted: Wed Aug 03, 2011 8:24 am
by Witzie
fuel pump is working, i feel a pulse when i hold the fuel line. Thanks for the tip about the dirt in the tank
, i will clean it and also the carbs as soon as i come back from my holiday in the holy motherland Italy.
Posted: Wed Aug 03, 2011 4:40 pm
by streetsurfer
Witzie wrote:fuel pump is working, i feel a pulse when i hold the fuel line. Thanks for the tip about the dirt in the tank
You might also check for aged and deteriorating fuel lines, if you've not replace them yet. It's not always noticeable from the outside but the interior could be degrading. When in bad shape then, they tend to kink, or restrict flow in tight bends. If/when changing them check the flow through the petcock. Blow low pressure air through it in reverse while cleaning tank out to make sure it is clear.
Verify fuel pump has a good ground.
Posted: Thu Aug 04, 2011 10:33 am
while you`re at it replace the fuel filter if it`s dirty and remove the fuel petcock from the tank. There`s a wire filter on the inner side of it you can check/clean. Do you have the original setup and carbs btw ?
Posted: Fri Aug 12, 2011 6:57 pm
by ducapaso
First of all I'd suggest you to check if the fuel pump is working properly. Release the fuel pipe close to the carb and turn the main switch on for 60 seconds. Do the same test with the tank full and almost empty, comparing the amount of gasoline in a proper bowl. You'll be able to see if it's true or not.
Another filter to clean is the one inside the petcock: remove it from the fuel tank and be careful not to damage its seal
Posted: Fri Aug 12, 2011 9:18 pm
by Mc tool
Hot tip ! remove hard plastic sealing washer and substitute with an appropreately sized O ring. Seals better without having to excessively tighten nut
( this is real helpful if the threads or the sealing surface arn't great)
