900 ss/sl engine
Posted: Thu Sep 08, 2011 8:15 pm
by wil-duc
hello, does anybody know if the 900 ss/sl engine from 1993 wil fit the 750 sport frame from 1990?
thanks,..
Re: 900 ss/sl engine
Posted: Thu Sep 08, 2011 8:20 pm
by higgy
lots of entries on the subject,use the search grasshopper
and add your general location to your profile
it just could be you have a neighbor has just that sorta thing in their stable
Posted: Fri Sep 09, 2011 1:38 am
by ducinthebay
Yes, it will fit if you have the 3mm spacers between the frame and engine on the right hand side. Use the SS swingarm, as the pivot pin is different. Drops right in. Been done several times. As Higgy points out, hit the SEARCH button on the header of this page and find the references and details.
Posted: Fri Sep 09, 2011 5:07 pm
by ir_joep
You will also need a complete exhaust system and probably some modification to the ignition. I'm not quite sure what a '93 900 ss has ignition wise.
Greetz (groet)
Joep
