Page 1 of 2
Clunck-oilspill-engine-no-more
Posted: Tue Sep 13, 2011 7:33 pm
by ir_joep
Just want to share this with all of you.
Today I was riding through town when suddenly CLUNCK the engine seized at once. I stopped in the street and the oil was dripping on the pavement.
I think I need some time in the shed...
Cheers Joep
Re: Clunck-oilspill-engine-no-more
Posted: Tue Sep 13, 2011 7:50 pm
by higgy
The infamous crank plug issue
Posted: Wed Sep 14, 2011 12:56 pm
by jcslocum
That sounds bad!!
Where was the oil coming from??
Posted: Thu Sep 15, 2011 3:16 am
by ducinthebay
Joep,
was that your 900 motor? does that mean you have a spare 750 motor?
Indeed, I see some shed time in your future. Bummer dude.
Phil
Posted: Thu Sep 15, 2011 6:39 am
by JoKing
SO sad...
Posted: Thu Sep 15, 2011 6:33 pm
by ir_joep
Thanks for the replies.
Yeah its the 900 engine. Did not have enough time to check what has happend. Still have the 750 which is in bad shape. But not as bad as the 900
Thanks again
Posted: Fri Sep 16, 2011 9:37 pm
by wil-duc
damm!! joep, das balen.
good luck getting it on the road again!
Posted: Sun Sep 18, 2011 7:00 pm
by ir_joep
Found out that the alternator cover was cracked. Suspect a run loose flywheel. It was me who torqued up and loctited the nut the last time....
Normally I do not use a puller to get the cover off. This time I will need one but I first have to make one.
Speak to you soon.
Joep
Posted: Sun Sep 18, 2011 8:56 pm
by higgy
Posted: Mon Sep 19, 2011 8:12 pm
by jcslocum
It may be recoverable!!
Posted: Sun Sep 25, 2011 6:16 pm
by ir_joep
OK,
Got the cover off and found a crack alternator rotor, which had seized the engine. How can this happen?
Cheers Joep
Posted: Thu Nov 24, 2011 8:05 pm
by wil-duc
hej Joep, whats up whit the bike / engine, any news?
gr.
Posted: Fri Nov 25, 2011 11:37 am
by ir_joep
Not much,
Like I said: cracked rotor which dislocated the altenator and that cracked the side cover. I do not know why the rotor got cracked in the first place but I did put it on so I think I have only myself to blame....
I currently looking at the orignal 750s engine the bike came with. I'm planning to overhaul it. So far I found 750 ss (low compression) pistons inside and what I believe to much play on the conrod big ends.
I'm also moving from one shed to an other. That doesn't help in the progress.
Thanks for asking
Cheers Joep
Posted: Fri Nov 25, 2011 12:00 pm
by higgy
if you hit a stator rotor with anything,its history. Can't drop them either.
Rare earth magnets are very easy to fracture. There are 14 rare earth magnets encased in lightweight aluminium making up the rotor. once any of the 14 are cracked its just a matter of time till the whole assembly comes apart. My guess is when it siezed inside the stator you probably twisted the crankshaft also at the very least.
On a positive note they does seem to be a fair supply of engines around most of the time
Posted: Fri Nov 25, 2011 5:40 pm
by paso750
most likely reason is overtightening the nut.
It`s essential it`s torqued correctly.
