Page 1 of 2
Frame Cutting/Chopping
Posted: Mon Sep 26, 2011 1:39 am
by Mustang505
I want to cut the rear section of my frame so the TT2 rep seat looks better once fitted - see pic below. I know some of you guys have cut the frame for various reasons, cutting that rear section loop under the rear of the seat, is it an issue frame structure/strength wise? My guess that part of the subframe is just there for plastic tray that was there?
Anyone thoughts before i take the angle grinder to it!
thanks
Re: Frame Cutting/Chopping
Posted: Mon Sep 26, 2011 4:30 am
by ducinthebay
That whole rear section is just to support you and your lady friend. You can take a lot of tubing out of it and still be good.
Look at some of the later model frames, and you will see a lot less frame in back, especially if you are putting on a single seat. It looks a lot like legacy ideas to me.
Cheers.
Posted: Fri Dec 30, 2011 7:31 pm
by wil-duc
Hej Clive, wy not use a 750 f1 replica race seat, that wil fit just fine, no cutting.
thats almost the same, but a littel bit wyder at the and, and a bit longer.
cheers, willem.
Posted: Fri Dec 30, 2011 10:28 pm
by higgy
Posted: Sun Jun 10, 2012 6:17 pm
by ducbertus
Hi Higgy,
you're right. I did this a while ago. Due to lot of things I didn't finish the project sofar.
Posted: Mon Jun 11, 2012 10:06 am
by angelix
AH!!!
I went all the way....
its nearly finished, 10 years working on this thing.
Posted: Tue Jun 12, 2012 8:18 am
by Andrew2
angelix wrote:AH!!!
Wow....that's awsome.Is there a thread anywhere about your build.
Andrew
Posted: Tue Jun 12, 2012 7:33 pm
by Bock900r
angelix wrote:AH!!!
Very nice project
Posted: Wed Jun 13, 2012 2:08 am
by ducinthebay
So is it basically a 748 with a 1989 Sport engine? (which happens to be 748cc)
What is left of the Sport?
Posted: Wed Jun 13, 2012 4:47 pm
by angelix
ducinthebay wrote:So is it basically a 748 with a 1989 Sport engine? (which happens to be 748cc)
Actually it is a little bit more complicated...
It is an SS 1997.... with a Elefant 750 Engine, with PASO polished heads, straight cut primary, dry clutch, NCR camshafts, FCR39s, FBF HC pistons, tweaked gearbox (half from a M620) balanced and lightened crankshaft-pistons-flywheel & rockers, polished and shotpeened (primary, rods) "new profile" cam pulleys, Ignitech ignition, Dynacoils... and... I forgot what else......
The rest comes from a 748R (rear end and part of the frame), 916 (front end, shock) , 996 (wheels , now I sold the 3 spokers and got a 5 spoke version), 999 (front brakes and Mastercylinders) ; the bodywork is nearly finished and it will be a Mix of 996 (seat and tail) 1098(front cowl, & headlamp), "supertwins" race bellypan, Supersport "mezzacarena" Faring Panels and Sport "nuovo" (Tank, is VERY narrow).
I have already the dashboard made and ready with a digital speedo (chinese), idiotlights, oil pressure & temp (VDO) and Revs (the revtacho is coming from a Yamaha RD350) and Shift light, but I am not entirely happy with it, so I dont know yet if I will keep it or go for something less complicated and more contemporary.
It started as a joke and half Elefant Engine and I got carried away.
Posted: Sun Jun 17, 2012 7:08 pm
by ducbertus
Hi Angelix,
very nice bike. Indeed you went all the way.
you finished, where I just started a long time ago.
meanwhile I collected parts such as
998R Öhlins front end incl. radial calipers
5 spoke magnesium Marchesini's
S4R swing arm (Aluminum sculputure)
changed the frame end to adapt the S4R link instead of the original cantilever.
But first I have to finish some other projects such as proper lathe to machine parts.
Bertus
Posted: Sun Jun 17, 2012 7:27 pm
by Mustang505
hey Bertus
where are you in Holland? i'm currently in Amsterdam on business for 2 weeks. hoping to get to Assen for the dutch TT before i fly home.
Posted: Mon Jun 18, 2012 4:34 pm
by ducbertus
Hey Clive,
I'm in the eastern part of Holland app. 100 km from Amsterdam. It's small town called Holten, directly near the highway A1/E30 Amsterdam-Berlin. Visiting Assen is also my goal, probably by bike (907) together with my friend on his 750ss or 888SP3.
I heard great things about New Zealand. my son was there a couple of months as a apprentice in Invercargill on a dairy farm.
PM me if you want to meet, for instance in the weekend.
Best regards,
Bertus
Posted: Wed Jun 20, 2012 4:21 pm
by ducbertus
hi Clive,
Still enjoying Holland?
how are you're TT plans?
maybe we can arrange something. it would be nice to meet you.
Bertus
Posted: Tue Oct 23, 2012 9:42 am
by micklm
Angelix - That is a most ambitious build. Awesome.
ducbertus - a lot of respect for you daring to cut the frame so far back. I'd love to see the finished product.
Has anyone else got photos of frame cut jobs? I'm considering cutting an SS frame down for a TT2 replica, and would be interested to see what has worked for others.
Thanks,
Mick
