wiring upgrade
Posted: Mon Sep 26, 2011 10:16 am
by desmodave
Ive wanted to do the upgrade since i first got the bike but i couldnt understand it at first now i know that mine is different - the four orange wires are divided into two connecters one used and one not for the upgrade.
but i just discovered that the left connector one of the wires crosses over to the other coil joining with the other two orange on the right!
any ideas fellas-shall i just disconnect? and go for it? has someone before me wired it this way for some reason?
on the upgrade wich side do you not use to the frame left or right ?
desmo.
Re: wiring upgrade
Posted: Mon Sep 26, 2011 11:11 am
by jcslocum
Can you post a picture of how your's is wired up??
Re: wiring upgrade
Posted: Mon Sep 26, 2011 3:47 pm
by desmodave
jcslocum wrote:Can you post a picture of how your's is wired up??
OK ive nevr had problem with it starting i have the weber tooand like it---the left coil(horizontal) is the orange wire that comes from above to the other coil orange wires the ones replaced by the y shaped upgrade part the lower end is still in the connecter horizontal side simple eh why didnt i see first time!
Re: wiring upgrade
Posted: Sat Oct 01, 2011 12:56 pm
by desmodave
desmodave wrote:jcslocum wrote:Can you post a picture of how your's is wired up??
no ideas anyone????
Re: wiring upgrade
Posted: Sat Oct 01, 2011 12:58 pm
by desmodave
desmodave wrote:desmodave wrote:jcslocum wrote:Can you post a picture of how your's is wired up??
no ideas anyone????
the orange wire comes down frome above so only bridges from the left connector to the other on the right coil.
Re: wiring upgrade
by desmodave
no ideas anyone????
