Page 1 of 4
My first new tyres
Posted: Wed Jul 20, 2005 12:42 pm
by Paul
When I bought my bike four years ago it came with a spare set of new Metzler tyres. I had a problem with the valve on the front wheel two weeks ago so I decided to replace the tyre at the same time. I had always thought that Ducati's should have good handling and was not impressed with the Paso (I even leaned a Buell over further during a test ride than I had ever managed with the Paso...).
Well, the new tyres are on and what a difference. She loves leaning over now. The first picture is of the old front tyre from when I just pulled off of Kyalami race track, marbles and all. The other two are before I test rode with the new tyres. All I can say is if you are having handling problems, take a good look at the tyres first. I also realised that these are the first new motorbike tyres I have ever had in all my years of riding.
The old front tyre -
The new front tyre -
and the new rear tyre -
Aren't they pretty ?
Paul
(self proclaimed sad git)
Posted: Wed Jul 20, 2005 3:15 pm
by fasterdammit
Yeah, what a difference! What tires are you running now? Sizes, too,please. Did you convert to larger rims? I'll bet you're loving it now, huh. :) :thumbup:
I know it's time for me to get a new set of sneakers, too ... the rear is starting to square off, so when it gets pitched into a corner it fights a little bit, then dives in. It's not bad - I've ridden worse - but I know where it's headed ... :umm:
Posted: Wed Jul 20, 2005 6:10 pm
by motiztab
Tyres do make a big difference. That’s why we used to cover the race tyres to keep the UV light off them. Our race engineer would never let a car race on tyres that had spent time in daylight; the rubber turns a blue’ish colour. Also can go hard.
I think that’s why the handling of my bike is not great. (Wobbles mid corner!) The Paso may be faster but I can ride the Triumph faster! I am just about to go a hunt for a set for mine
Posted: Wed Jul 20, 2005 9:27 pm
by redpaso
Paul, you really need to get out there & ride more mate. :D
Any tyre that is not used much will go off as Motiztab stated & is not that much fun to ride. Nice new rubber, details please.
How about some shots of the whole bike too.:cool:
As for lean angles I think the Paso leans right over no problem & I have wear on mine right to the edges which if you tip the bike (stationary in the garage) equates to some pretty serious lean. The key to stopping a tyre "Squaring off" is to aviod long straight boring freeways. I don't ride unless there are going to be some good curves invlolved. Keeps the wear even & the adrenalin high. :thumbup:
Posted: Fri Jul 22, 2005 5:30 am
by Paul
Instead of just putting the sizes I went and had a look at what was written on the tyres.
Front :
Metzler MEZ1 130/70 ZR 16 (61W)
Rear :
Metzler ME1 MBS 160/70 VB 16 (71V)
So as you can see, I still have the standard 16 inch wheels. The middle of the tread on the rear tyre almost touches the swinging arm. There are only a couple of millemetres to spare. This is with the axle in the lowest position in the concentric adjuster.
I have photos that I took of the whole bike and will start the process of putting them in the gallery today.
Paul
Posted: Fri Jul 22, 2005 6:12 am
by redpaso
Thanks Paul,
Please get some miles under the bike & let us know how she handles / wears with this rubber. Also let us know if you have any trouble with expansion due to heat that results in rubbing on teh swingarm. Always good to know of tyre options.
Looking forward to the pictures. :thumbup:
Posted: Fri Jul 22, 2005 6:22 pm
by fasterdammit
Indeed - I'm curious about the 70-section tires, as I believe 60-section were the original spec. Metzler is the last company to my knowledge to make a matched pair of 60-section rubber - I think the A59s? 130/60ZR16 and 160/60ZR16s maybe (not sure about the Z rating though).
And it's time for a new pair for me ... I think I'm in the 8-9k range on the rear, and it's squared to the point where it takes a little muscle to get it past the transition, and then it dives right in ... :eek:
Looking forward to pictures, too!
Posted: Sat Jul 23, 2005 5:13 am
by mike
fasterdammit wrote:Indeed - I'm curious about the 70-section tires, as I believe 60-section were the original spec. Metzler is the last company to my knowledge to make a matched pair of 60-section rubber - I think the A59s? 130/60ZR16 and 160/60ZR16s maybe (not sure about the Z rating though).
I think you meant Michelin?
I too am interested in this setup. Michelin is on my shit list after the USGP. I spent quite a bit of time talking with reps from Bridgestone and Pirelli about our 16" tire problem. Why can't we have our Pirellis back?!?! :sad:
Posted: Mon Jul 25, 2005 2:21 pm
by fasterdammit
whups ... right you are - Michelin, not Metzler. Good catch! Got M on the brain ...
I would love to replace them w/ Pirellis ... !
Posted: Tue Jul 26, 2005 10:29 am
by fklemenz
well,
I used the Michelins for a couple of years but I am not that happy with the performance.
After a while I found another possibility.
So I just ordered the new Metzeler Lasertec:
150/80VB16 M/C (71V) TL Lasertec METZELER
120/80VB16 M/C (60V) TL Lasertec Front METZELER
I will post a report as soon as possible...
regards
fklemenz
Posted: Fri Jul 29, 2005 4:09 pm
by ducapaso
Do your local policemen let you ride with such tyres or you ride only in racing circuit?
In italy it's not possible ride with something different of 130/60-16 and 160/60-16 :mad:
Posted: Mon Aug 01, 2005 6:04 am
by fklemenz
The dimensions are possible in Germany,
I have a certification from DNL Ducati Germany for the Dunlop Sportmax in the same size. You only have to do a 'few' modifications because the wheels are a bit higher then. They should not scratch the swingarm or even the chain.
fklemenz
Posted: Mon Aug 01, 2005 11:25 am
by fklemenz
OK,
The copies of the certifications for the german TUEV are at home.
I will scan them and send them to your email adress tomorrow.
Anyway they are for the 750 Sport not for a Paso but the paso and the sport have the same wheels, you can ask the guys at the TUEV before buying the tyres.
Posted: Mon Aug 01, 2005 11:28 am
by fklemenz
Hi again,
there's something I forgot:
http://www.ducclub.de/technik/750s.htm
Thats a page decribing the problems with the 16" wheels
CU
fklemenz
Posted: Mon Aug 01, 2005 12:41 pm
by Paul
fklemenz,
Can you give us an overview of what the page says ? It doesn't have to be word for word.
Paul
