ST 2 CAMS???
Posted: Mon Feb 20, 2012 7:27 am
by oceanhunter
Does anybody know if st2 cams fit in 907?if so any mods required,any gains
to be had?
Just pulled heads off to fit mbp collets
,ordered
ohlins shock
fitted braided lines all round
(thanx mr speigler)
but broke cam belt idler pully bolt
,replacing belts and rollers and dial in cams
wish me luck
have five weeks to get back together for
trip down west coast nz for best little airshow inthe world
Re: ST 2 CAMS???
Posted: Mon Feb 20, 2012 12:29 pm
by Derek
They should fit straight in but you will need to completely re-shim all the clearances.
Re: ST 2 CAMS???
Posted: Mon Feb 20, 2012 4:37 pm
by Bock900r
And how to connect the tachometer cable? Or do you have a electronic Instrument?
Re: ST 2 CAMS???
Posted: Tue Feb 21, 2012 10:15 am
by Derek
Bock900r wrote:And how to connect the tachometer cable? Or do you have a electronic Instrument?
I was told, only last week, by a friend who is working on a 900SS project bike that the worm gear on the camshaft is simply an interference fit. So it could presumably be removed from the 907 camshaft and transferred to the ST2 one.
Re: ST 2 CAMS???
Posted: Tue Feb 21, 2012 12:55 pm
by higgy
The hard part will be finding the cams
Re: ST 2 CAMS???
Posted: Tue Feb 21, 2012 3:21 pm
by Bock900r
Derek wrote:Bock900r wrote:And how to connect the tachometer cable? Or do you have a electronic Instrument?
I know it from the SPS cams, they has to be modyfied by machining to fit the interface.
This was done on my 888 with 996SPS engine
Here a link, only in German
http://www.first-attack.de/Tuning/Drehz ... trieb.html
Re: ST 2 CAMS???
Posted: Thu Feb 23, 2012 8:02 pm
by mh906evo
I just got a pair for my 907, I can say that they are a perfect fit. The problem is to get them for an acceptable price if you don't want to buy them new for about 700€ (prive in Germany)
Good luck !
Rainer
Re: ST 2 CAMS???
Posted: Fri Mar 09, 2012 3:25 pm
by JoKing
Bock900r wrote:Derek wrote:Bock900r wrote:And how to connect the tachometer cable? Or do you have a electronic Instrument?
I asked them for a ST3 camshaft conversion to mechanical tach attachment for 907. They said they won`t do for a std.-price, it would be a prototype w. all costs that are coming with this fact...
Re: ST 2 CAMS???
Posted: Fri Mar 09, 2012 7:06 pm
by ottovalvole
Hi
Why fit ST2 cams?
Re: ST 2 CAMS???
Posted: Fri Mar 09, 2012 7:59 pm
by higgy
more overlap in the timing = more power on the high end of the rpm band
