Ducati Paso vs Cagiva Freccia MIRRORS - differences
Posted: Tue Mar 06, 2012 7:30 pm
by Truten
Hi!
I have opportunity to buy Cagiva Freccia mirrors and I have doubt if they will fit Paso 750 without modifications. Are there any differences between this two types of mirror? The main problem is that I haven't seen them in real, only in a picture.
Greetings
Peter
Re: Ducati Paso vs Cagiva Freccia MIRRORS - differences
Posted: Wed Mar 07, 2012 8:49 am
Hi Peter,
we have a search function
The Freccia mirrors look very similar from the distance but have numerous differences. To mount them you`ll need to drill 3 holes and carefully grind their outer edge if you want them to sit properly in the recess of the headlight fairing.
Some pictures:
http://forums.ducatipaso.org/viewtopic.php?f=1&t=3723
Posted: Fri Mar 09, 2012 12:44 pm
by JoKing
Well, i own a 907 and a freccia C12R, the freccia has the bolt-on attachment-type, while the 907 has the click`n snap attachment. But don`t some of the pasos have the click`n snap attachment as well?
On the first glance it seemed to me to be the only relevant difference (except the more "wobbly" plastic used for the freccia-mirror)
Next week i could make some pics for comparison....
Posted: Fri Mar 09, 2012 4:53 pm
Not some, they were all like that.
Pictures are in the link above. If you directly compare an original and a FAR mirror you will discover many small differences. However overall they look quite similar.
