Page 1 of 2
Norway callling! New member.
Posted: Sun Mar 25, 2012 7:59 pm
by reo
Re: Norway callling! New member.
Posted: Mon Mar 26, 2012 4:37 pm
by randtcastell
Absolutely gorgeous! perhaps my favorite Ducati model of all time. Thanks for showing us the pictures. Change out that rear tire or be careful.
Posted: Mon Mar 26, 2012 7:13 pm
by ir_joep
Very Nice bike. Especially like the 2 in 1. Who made it?
Greets Joep
Posted: Mon Mar 26, 2012 7:43 pm
by reo
randtcastell wrote:Absolutely gorgeous! perhaps my favorite Ducati model of all time. Thanks for showing us the pictures. Change out that rear tire or be careful.
Thank you. Agree.
Best regards Rune
Posted: Mon Mar 26, 2012 8:00 pm
by reo
ir_joep wrote:Very Nice bike. Especially like the 2 in 1. Who made it?
Greets Joep
The muffler are GIA.CA.MOTO. I do not know but I think this is from Gianelli. Anybody know?
Best regard Rune.
Posted: Mon Mar 26, 2012 9:06 pm
by bmw851
Welcome, and love the 2 into 1's look great, floating front disc conversion, from who? my 280mm brembo's are warped
and need to replace.
Peter
Posted: Tue Mar 27, 2012 2:37 am
by ducinthebay
Nice job on the rear cowl mod. Is that stock parts fused together, or did someone do a fiberglass redo?
I see the stock pillion pegs/muffler hangers have been removed.
Exhaust looks like the GiaCoMoto that I have bits of, but yours is complete.
Welcome to the site.
Did you do most of the work, or was it the previous owner/s? Whats on your list for next steps?
Posted: Tue Mar 27, 2012 9:00 pm
by reo
bmw851 wrote:Welcome, and love the 2 into 1's look great, floating front disc conversion, from who? my 280mm brembo's are warped
Peter
Hello.
I do not know where the brake discs are coming from. I can try to check it out later. I also like the style of the exhaust system, but are not as excited by the sound. Miss the "real" sound of a duc, with 2-2 exhaust.
Best regard Rune
Posted: Tue Mar 27, 2012 9:33 pm
by reo
ducinthebay wrote:Nice job on the rear cowl mod. Is that stock parts fused together, or did someone do a fiberglass redo?
Hello.
It is stock parts fused together on the rear cowl. All modifications made by previous owners, and I think everything was done when the bike was relatively new, so the bike is a time capsule from a bygone time.
It has been my for 3 years now, and the next plan is to get new tires, new air filter (these are custom made from UNI Filter, Australia), and I'll try installing a 2.2 system with carbon silencers (SIL) from a 750Ss 1998 as a friend of mine is running. I'm not so happy with the sound at 2-1 exhaust GIA.CA.MOTO.
UNI Filter mountet on DelLorto PHM41HS.
Posted: Tue Mar 27, 2012 9:44 pm
by reo
Hi.
Here are some more pictures with the correct color on the bike and its surroundings.
Its not me in the saddle.
Best regards Rune.
Posted: Wed Mar 28, 2012 2:44 am
by ducinthebay
Those carbs are a bit big for that engine, but if you get them to run OK, then I guess they're OK. 36mm is the recommended size.
I recommend putting big rubber elbows on those carbs and put some big sock filters on top of those up above the carbs. Gets the intakes into cooler air, gives you bigger air cleaners, and smooths the flow of air coming into the carb.
When you get your new pipes, you can easily sell that set up here on the list. It is one of the few 2 into 1 pipes, and produces good power, but it is loud.
Posted: Thu Mar 29, 2012 8:05 pm
by Mc tool
Posted: Fri Mar 30, 2012 7:23 pm
by reo
Posted: Sat Mar 31, 2012 7:27 pm
by reo
ducinthebay wrote:Those carbs are a bit big for that engine, but if you get them to run OK, then I guess they're OK. 36mm is the recommended size.
Hello, and thank you for your feedback.The bike runs like a dream on the carburetors mounted on. I agree that the horizontal cylinder should have the benefits of fresh cold air and rubber elbow helps to even out the airflow. But the airfilters are large enough, dont you think?
Posted: Sat Mar 31, 2012 7:29 pm
by reo
