Wanted Piston and cylinder set
carrera
Post by carrera »
Hi I just bought a 1990 Ducati paso 750 and on start up it snap a inlet valve. After having been sitting for a couple of years according to the seller it haqd a Ducati rattle. Well i have managed to get a head but the piston is mashed and the bore is marked.
Also I have come accross a dealer that closed his Ducatti sale several years ago and has old stock but needs part numbers as his system has been corrupted. So if anyone has a list of part numbers especially for the piston, ring, cylinder block.
Thank great
Kim Carrera
Ps I am in Queensland
Australia but i buy stuff from all over the world
Jaffa
Re: Wanted Piston and cylinder set
Post by Jaffa »
Ian Gowanloch will have these in stock.
He can catch him on 02 69462626
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
Duc906
Post by Duc906 »
If you're after part numbers, there is a parts catalog in the 750 thread.
Have a look here: http://forums.ducatipaso.org/viewtopic.php?f=1&t=1551
englishstiv
Post by englishstiv »
If you do need some Pistons etc then try these if no luck your end - may even be cheaper with the exchange rate/postage aswell, I know they had some on show the other week at a local bike event and they regularly deal with Aussie owners racing 750 Dukes. They should be able to help with part numbers as they seemed very happy to offer advice.
http://www.twowheelclassics.co.uk/
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
carrera
Post by carrera »
Thanks for your help
carrera
Post by carrera »
Jaffa wrote:Ian Gowanloch will have these in stock.
I owe you thanks. KIM carrera
there`s currently a used set on ebay
http://www.ebay.com/itm/Ducati-Pantah-T ... 43aec577e7
The only question is from what model these actually are as the SS has a lower compression than the Paso & Sport.
