Starter issue
Posted: Thu Apr 05, 2012 11:29 pm
by jrichardsmcq
Starter issue..I'm sure this topic has been discussed, but here i go. Had not run the 907 over the winter and although the battery was on a tender it was shot..After installing a new one the bike started but had some chatter in the starter..Tried starting a week later now the starter engauges for a second, turns over the engine and then kicks out the selenoid and just spins..Give me the bad news..I need to hear it from the experts. Thanks guys
Re: Starter issue
Posted: Fri Apr 06, 2012 1:58 am
by higgy
sprag spring
Re: Starter issue
Posted: Fri Apr 06, 2012 3:27 am
by Stingray230SX
here is some info:
Chances are the sprag clutch spring has weakened or come apart. A replacement spring from an oil seal (part # CR 19778) for around $6- works perfectly.
The part # CR 19778 is for an oil seal (CR is for Chicago Rawhide - the maunfacturer). The seal (probably a grease seal) has a spring around the inside of the rubber lip. That spring is a perfect replacement for the starter sprag spring in the starter sprag assembly. Throw the seal away and keep the spring... that's all you need.
https://ccrma.stanford.edu/~peer/Duc/du ... pring.html
http://forums.ducatipaso.org/viewtopic.php?t=651
Re: Starter issue
Posted: Sat Apr 07, 2012 1:18 am
by jrichardsmcq
Thanks.. the side cover is off and I'll get a little further along tomorrow. Kinda new to these motors. I guess it wouldn't be a bad idea to freshen up the starter while I'm at it.
Re: Starter issue
Posted: Mon Apr 09, 2012 9:20 pm
by Stingray230SX
its not too bad, i actually did it on my parents front porch before i bought my house with a garage.
just remember to note where those side cover bolts went , as they are different lengths.
doug hunt
Re: Starter issue
Posted: Mon Apr 16, 2012 3:50 am
by jrichardsmcq
Thanks guys. Took it apart and the spring was shot. I got the seal, pulled out the spring and it's back together with all the bolts in the right places and starting just fine..Appreciate all the advice because I didn't have a clue...I'll never claim to be a mechanic but with your help I'm one step closer..
