simple solution transfer to 180 bridgestone
Posted: Thu Jun 21, 2012 5:21 pm
by Brutus
Re: simple solution transfer to 180 bridgestone
Posted: Sat Aug 04, 2012 9:01 am
Hi, you`re better off replacing those toothed washers with normal ones and using Loctite instead.
Those things are ok for electrical connections but not for much else. Most of the toothed or spring washers will already be squashed at only 5% of the bolt`s preload force so they become ineffective long before the proper torque is reached.
Also it makes no sense putting them between a bolt and a washer.
Never mind, just want everyone to be and stay safe.
PS: does the front sprocket still have play ? There should be about 0,3mm if my memory serves me well.
Posted: Sun Aug 05, 2012 11:12 am
by Brutus
Tx for the reply. I used washers and loctite. You're right, I'll get those washers out. Furthermore, currently there is no axial play, cause its directly bolted on the axle. I could machine this with a small bushing that sticks out 0,3mm. Agree?
Léon
Posted: Sun Sep 02, 2012 9:24 pm
by Brutus
paso750 wrote:Hi, you`re better off replacing those toothed washers with normal ones and using Loctite instead.
Cause the previous construction didn't had any axial freeplay at all, I've made something else. The first plate (see first picture on top of this page) is used to mount the sprocket and it touches the axle for the desired offset. The center hole of this plate I've milled allot wider. In this hole there is another bushing fitted, but approx 0,3mm thicker than the first plate. It is not "connected" to eachother, but it'll keep the first plate in place. I've used loctite 2701 to be sure it won't come off.
Posted: Thu Dec 27, 2012 9:05 pm
by Jeffreyt
Hello Léon,
After reading your solution transfer to the 180 bridgestone. I have not replaced the tires on my '87 Paso before and am not quite following your process. It appears that you only posted pictures of the forward sprocket. It looks as if you put the 5mm spacer between the sprocket and the engine. Did you just put spacers between the rear sprocket and the wheel? I really appreciate any help you may offer as I am not a great mechanic. I'm more of a body guy.
Posted: Fri Dec 28, 2012 9:32 am
by Brutus
Below a couple of pictures of the current setup. As an extra 'ensurance' I've added a strip that will prevent losing the central bolt. The rear sprocket is offset as I used an old alu sprocket and turned it down on a lathe.
Posted: Fri Dec 28, 2012 10:23 am
No, what he did was the combination of 2 things. Leon used a sprocket with less offset and moved it to the end of the drive shaft.
It`s basically this:
The bigger plate has a center hole that`s smaller than the driveshaft diameter so it doesn`t allow the sprocket to move inwards. The smaller part sits in the bigger plate and is mounted to the driveshaft by the center bolt. This prevents the sprocket to come off the driveshaft and still lets the sprocket its required axial play.
Posted: Fri Dec 28, 2012 10:43 am
by Brutus
and a quick drawing of the current setup.
Posted: Fri Dec 28, 2012 10:48 am
by Brutus
paso750 wrote:It looks as if you put the 5mm spacer between the sprocket and the engine.
Thats it!
Furthermore I used an 851 sprocket with approx 16mm width. Compensates the gap for the original clip in the axle.
Léon
Posted: Sat Dec 29, 2012 2:11 pm
by Jeffreyt
Thanks Leon,
I appreciate the drawings. A picture worth a lot, etc. Any suggestions on where to get the two sprockets?
Thanks for everything. I feel like I can do this properly now.
Jeffreyt
Needham, MA
Posted: Sat Dec 29, 2012 5:33 pm
by Brutus
