Frankenstein Paso
Posted: Sat Aug 11, 2012 7:17 pm
by Clint750
1988 750 Paso rescued from ditch. All bodywork destroyed. Forks literally torn from bike.
Features:
17" 750SS wheels with stock brakes
38mm Mikuni CV 750SS carbs
750SS oil cooler
Adjustable clipons clamped to adapters bolted to triple clamp
Re: Frankenstein Paso
Posted: Sat Aug 11, 2012 8:52 pm
by ducinthebay
Nice interpretation of the Paso. I like it.
You'll like the Sport I am building.
Posted: Sat Aug 11, 2012 9:37 pm
by randtcastell
I'm really impressed with your dash and instruments. Great imagination and fabrication. Thanks for sharing. Looks like a sweet ride.
Posted: Sun Aug 12, 2012 2:54 am
by Andrew2
Nicely done
Andrew
Posted: Mon Aug 13, 2012 8:06 am
by Brutus
Didn't realize that there is enough room for a 17" front wheel and an oilcooler under the front yoke in combination with the M1R.. Nicely done.
Posted: Mon Aug 13, 2012 6:49 pm
by scimmione
Nice job! With a single larger oil cooler, I'm guessing oil capacity is greater? What kind of temps do you run when idling at stop signs, etc..?
Posted: Mon Aug 13, 2012 7:27 pm
by Clint750
I've never had an oil temperature gauge on the Paso, but my longtime Ducati guru experimented with gauges on his Elefant and his bevels. Our observation was that Ducatis are easy on their oil. He ended up taping over the Elefant's cooler to raise operating temps. Of course, we do live in Washington, where temps are moderate.
I put the Paso together 15 years ago and ran without a cooler for most of that. Hasn't melted down yet!
Posted: Thu Aug 16, 2012 2:05 am
by ducinthebay
I like the short fork guards you have on there. Where did you find those? They were stock on some Kawasaki's, but I'd love to know which ones fit the M1R fork.
Phil
Posted: Thu Aug 16, 2012 2:30 am
by Clint750
Sorry to say, I cut them from a plastic bottle. Secured by hose clamps. Sophisticated, huh?
Posted: Thu Aug 16, 2012 4:23 am
by ducinthebay
In true FrankenPaso style. Nice trim job.
Posted: Thu Aug 16, 2012 3:35 pm
by stylianos62
....yes....sometimes it could be happen, the matter is to avoid......to meet creatures like this!!!
Posted: Fri Aug 17, 2012 7:49 am
by Andrew2
Clint750 wrote:Sorry to say, I cut them from a plastic bottle. Secured by hose clamps. Sophisticated, huh?
Love it
Andrew
Posted: Sat Sep 29, 2012 8:32 pm
by Duc750
U think the 750 is over cooled as stock
I used to use two sponges wrapped in foil to partially block the cooler vents in the fairing to brign the temperature up into the right range for most of the year
Posted: Tue Oct 02, 2012 6:10 pm
by plasmid
Pretty wild.
Maybe you can drop an Ipad in as the dash also?
