throttle bodys
Posted: Tue Oct 02, 2012 5:44 pm
by johnm
does anyone out there know where i can get a set of throttle body assembleys for my 1991 907 the shaft bushings are leaking air and i cant find anyone that can rebush them.
Re: throttle bodys
Posted: Tue Oct 02, 2012 6:20 pm
by Derek
Just wondering if the ST2 throttle bodies will fit? The throttle body from one of the injection SS models could be better as they have the pressure regulator mounted on them.The air bleed screw arrangement is different and it uses a different TPS which may need changing the connector if you can't swap the TPS over. Neither does it use the 8-pin round connector but that could be easily added. It would certainly be worth a look.
Re: throttle bodys
Posted: Tue Oct 02, 2012 6:42 pm
by Crumpati
Gowanlochs ad them about 6 months ago on eBay for about $300 AUD brand new.
Re: throttle bodys
Posted: Wed Oct 03, 2012 12:01 am
by nickta
I picked up the complete set from Italspares in Aust about a month ago. They may still have a set or 2? I have the phone number here somewhere....
Re: throttle bodys
Posted: Wed Oct 03, 2012 8:43 pm
by ducbertus
Hi John,
are there realy metal bushings in the throttle body?
I thoughed it's all plastic.
when there are metal bushes they can ber rebushed.
just machine them out on a mill. insert some new bronze bushings and ream them in line with a adjustable reamer. or a fixed one. reamers are available in several sizes in steps of 0.01 mm. I use a set of these for reaming valve guides.
Bertus
Re: throttle bodys
Posted: Fri Oct 05, 2012 2:00 pm
by johnm
johnm wrote:does anyone out there know where i can get a set of throttle body assembleys for my 1991 907 the shaft bushings are leaking air and i cant find anyone that can rebush them.
nickta did you find the number for italspares.
Re: throttle bodys
Posted: Fri Oct 05, 2012 3:52 pm
by 20YearOwner
I have purchase hard to find Weber parts from a seller on ebay using the name "alfa1750" if you are an ebay member you could try to contact him, if not he mostly sells Weber carburetor rebuild kits. Do an ebay search for WEBER CARBS REBUILD KIT you should be able to find him. Use the "asked a question" box and give him a number he will email you with a price if he has the part.
Re: throttle bodys
Posted: Fri Oct 05, 2012 10:18 pm
by johnm
ducbertus wrote:Hi John,
Bertus
thanks very much i think tonight i will remove them and see if there is any way to rebush them.
Re: throttle bodys
Posted: Sat Oct 06, 2012 12:09 am
by nickta
Italspares Phone Number is +61 2 6946 2626. Speak to Jim or Ian. I rang them the other day, and Jim said he thought there might be another set there.
They have a few spares for the Paso/907. Pretty good prices too.
Cheers.
Nick.
Re: throttle bodys
Posted: Tue Oct 23, 2012 6:54 pm
by johnm
thanks to every one for the responses. nikta thanks i just got my new throttles from italspares, fantastic thanks again
john
Re: throttle bodys
Posted: Fri Oct 26, 2012 9:16 am
by nickta
Hi John.
No worries about the phone number. Glad I could help.
I spoke to Jim yesterday and he said Italspares will be going online with their parts in the next month or so. Keep an eye out if they do.
Cheers.
Nick.
