Clutch pump 999
Posted: Thu Feb 14, 2013 6:29 pm
by duc34
Hi!
Who has made something like that already?
I'm on the way to change the pump of the braking and the clutch of my 907.
How did you manage, that the starter level (Choke / Levetta per starter?) on the left hand is working?
Is it possible to lay the cable to the underside?
Would someone be so kind to make a photo from underneath?
Thank you.
Ahab
Re: Clutch pump 999
Posted: Thu Feb 14, 2013 6:42 pm
by paso750
that starter assy is mounted upside down.
(do you have an Alfa ? That tool on the wall looks somehow familiar)
Re: Clutch pump 999
Posted: Sat Feb 16, 2013 6:59 am
by persempre907
Io ho la stessa pompa sui freni anteriori e mi ha cambiato la vita.
E' veramente tutta un'altra cosa.
Avevo comprato anche la pompa frizione su ebay (entrambe provenienti da un 999) ma il meccanico mi disse che non poteva andarci sul Paso.
Comunque ha ragione G.: devi ruotare lo starter in avanti. Adesso รจ in posizione sbagliata.
Buon lavoro :thumbup: :thumbup: :thumbup:
I've got the same brakes' master cylinder on my red 907 and it has really changed my life.
It grants a very stronger braking.
I bought the couple of master cylinder from a 999, but the mechanic told me the clutch master cylinder did not fit on the Paso.
Really, I don't know why.
However, G. is right, you have to rotate the choke assy which now is wrong.
Re: Clutch pump 999
Posted: Sun Feb 17, 2013 4:20 pm
by duc34
Hi guys,
of course i know that it's upside down, because it didn't fit. I rasped down one of the black pins, and now it works. The starter wire is very close to the clutch line.
The tools are for bevel Ducatis.
Re: Clutch pump 999
Posted: Sun Feb 17, 2013 5:13 pm
by persempre907
What about those 2 switches on the left?
Che sono quei due pulsanti a sinistra?
Curioso come una scimmia :lol: !!
Re: Clutch pump 999
Posted: Sun Feb 17, 2013 6:53 pm
by Duc750
persempre907 wrote:What about those 2 switches on the left?
Shifttronic or similar "power shifter" ?
Re: Clutch pump 999
Posted: Sun Feb 17, 2013 8:39 pm
by duc34
It's a
http://www.translogicuk.com/powershifters.php
I lost parts of my left leg, so I have to shift this way.
Re: Clutch pump 999
Posted: Sun Feb 17, 2013 11:13 pm
by persempre907
I'm really sorry.
I could not imagine such thing.
Sorry again.
